Sponsored by: Kumho
leaky brake valve name
Old Sep 30, 2004 | 07:06 AM
84-250's Avatar
84-250
what is the name of the brake valve thats mounted on the frame and connects to the diff by a lever? the one that allows more braking with more weight in the bed.
where can i find a replacement one?
Old Oct 1, 2004 | 08:05 AM
jtmerritt's Avatar
jtmerritt
My guess is that it is called a proportioning valve.
John
Old Oct 2, 2004 | 12:21 PM
84-250's Avatar
84-250
i think that the proportioning valve is up front under the master cylinder and controls the fluid between the disc and drum brakes. the valve im talking about is right above the rear axle and connects to it by a lever. it controls the braking power for the rear drums.
has anyone had to replace it and where did you get it?
Old Oct 2, 2004 | 04:40 PM
angus's Avatar
angus
The combination valve up front normally includes a proportioning valve, but in this case the proportioning valve is tied to the rear axle so that when the truck is loaded more heavily, more braking is done by the rear brakes. I'd guess that the only place you'll get a replacement valve is from Ford or from a wrecking yard.
If it's a big deal to get another stock valve, you could replace it with a Wilwood adjustable prop. valve.
jdbanks
Feb 20, 2015 01:12 PM
jetfiremuck
Aerostar
Sep 27, 2014 05:13 PM
curtisbutlerjr
Jun 17, 2014 02:18 PM
michaeljoe6
18
Jun 21, 2007 03:21 AM
hooba2
Apr 6, 2004 09:40 PM
