Intermittent hard start
Old Sep 29, 2004 | 12:53 PM
mook's Avatar
mook
95 Exp 4.0 - replaced fuel pump relay twice (helped for a while), problem back again, and advice from thread suggested "initializing" instrument panel with key ON and THEN cranking engine. It will start this way, but what is causing it? Some have said electrical power "robbed" by "initializing".? This seems too common not to get thousands of answers.............Thanks!
Old Sep 30, 2004 | 09:57 AM
thelonerangerxlt's Avatar
thelonerangerxlt
Mook, the "initializing" is just a stopgap measure; it shouldn't be needed for a normal start. First check the plug-in for the fuel pump. Un-plug it and spray with WD-40 or something similiar. If this dosen't help, I suspect you have a fuel pump on the way out.....sorry to say it's probably a bad pump.
Welcome to FTE!
abyars111
Nov 4, 2013 07:19 PM
66flareside
May 25, 2009 06:44 PM
MeanGreen66
Feb 9, 2009 02:14 PM
fordtruck44
Jun 20, 2008 02:24 PM
SouthBay420
Modular V10 (6.8l)
Sep 3, 2003 04:01 PM
