too much timing
Old Oct 31, 2013 | 12:03 AM
abyars111's Avatar
abyars111
too much timing
Will too much initial timing cause an engine to run warmer at highway speeds under a load? I run warm when towing (200) and have replaced everything. I checked my timing for the first time today, the hold down was loose and the initial was at 30! I backed it down to 6. Besides being easier to start I wonder if it might cool it down some when towing.
Old Oct 31, 2013 | 08:48 AM
69cj's Avatar
69cj
Possible. I surprised it wasn't pinging to beat hell. Your pistons will be much cooler, that I can guarantee.
Old Oct 31, 2013 | 11:13 AM
montana_highboy's Avatar
montana_highboy
Have you verified that by checking TDC?
My guess is your balancer has slipped.
30 degrees initial would be very difficult, if not impossible to start....not to mention ping like crazy.
Old Oct 31, 2013 | 11:19 AM
abyars111's Avatar
abyars111
I didn't think about the balancer slipping. I may have actually retarded the engine. I will check it.
You know the more I think about it I realize that I accidently moved the dizzy before checking it because the hold down was so loose. So it may have been set differently than I observed.
I did have to reset the idle RPM, I had to increase it by about 150 RPM after I reset the timing.
I check TDC and see what I find. Thanks for the advice.
Old Nov 1, 2013 | 11:27 AM
montana_highboy
No problem....let us know what you find out, i'll be surprised if there isn't a little slippage going on.
Old Nov 1, 2013 | 07:38 PM
1972RedNeck's Avatar
1972RedNeck
I'd vacuum time it and see what you light says.
Old Nov 3, 2013 | 02:31 AM
montana_highboy
Good point Red, I assume the OP disconnected the vacuum advance when he threw a timing light on the motor.....
(though it would only matter if he was sourcing manifold vacuum for his advance)
Old Nov 3, 2013 | 01:44 PM
abyars111's Avatar
abyars111
I disconnected the vacuum advance to check the timing. I'm using the timed vacuum port for the vac advance. My balancer is in good shape and if it slipped its too minimal for me to tell after checking TDC. I think my bumping the dizzy and moving it before I checked the timing resulted in my high reading. I have it set at about 8 now and it runs and pulls good. For kicks I drive it set at 0, wow what a dog. Friday night I hauled our camper 3 hours to visit family and the truck did well. We are loading up now and heading home.
Old Nov 4, 2013 | 01:25 AM
montana_highboy
On a stock FE I like to run 10 or 12 initial (as long as the motor doesn't rattle)
Old Nov 4, 2013 | 07:19 PM
1972RedNeck
On a bone stock 360 20* initial won't make it ping. 25* will make it ping if youlug real hard. It doesn't start at that though.
johnson2007
May 8, 2011 07:51 AM
tdford
Jun 4, 2006 11:04 PM
Kemicalburns
1978 - 1996 Big Bronco
Nov 26, 2003 12:24 PM
Old5
Feb 26, 2003 01:55 PM
Ratsmoker
May 26, 2002 03:00 PM
