I have a 390 with a stock holley 4bbl. and i was wondering what they initial carb settings are for that. I am cleaning it and then putting it on my engine, so the initial settings would be usefull for start up. Thanks .
If the carb has external float adjustments, there will be a flat blade screw with a locking nut installed in the top of the float bowl. If it does not have this adjustment, then the float has to be set while the carb is disassembled. You can look up the carb specs on-line. The carb shown at the website below shows the float adjustment on the top of the float bowls...
Okay thanks, Is there a way to identify more on the engine by looking at the block, i don't know what it came out of. I would also like to know the year and maybe if its a car or truck model.
Ford 390 66-67 Cougar, 66-68 Mustang, No Smog, 14 manifold bolts per head Applications
1964-1967 Ford Ranch Wagon 1967 Ford Mustang 1967 Ford Ranchero 1964-1967 Ford Country Sedan 1964-1967 Ford Thunderbird 1964 Ford Country Squire 1964 Ford Fairlane 1966-1967 Ford Fairlane 1964-1967 Ford Custom 1964 Ford Victoria 1964-1967 Ford Galaxie 1965-1967 Ford LTD 1964 Ford Sunliner 1964 Ford Club
The 390 cid is part of the Ford family of big block FE series engines: 332, 352, 360, 361, 390, 391, 406, 410, 427, & 428. All the blocks look the same, but they look entirely different from the small block Ford V8's. The FE began in 1958 as a 332 or a 352 in the big Fords. In 1965 it became available in the F100, and continued through 1976 (in the F100). Most all external parts that I can recall will interchange on the FE. On the inside, of course, there's a hodge podge of different pistons, rods, cranks, etc. Identifying Ford parts can be a real problem until you get the hang of it, so it's a good idea to get a book on this if you're going to be keeping this car/truck. If you have no way of knowing what's been changed on the motor previously by some other owner it gets even harder. If the motor appears stock you can look in front of the carburetor on the intake manifold for a part number. If the number begins with a "C" the intake was made in the 60's, a "D" indicates an intake from the 70's. Everything other Ford part uses this numbering system but that doesn't help you ID the block though. All this info is available in numerous Ford books.
Most casting numbers are stamped into the part itself, other have the number molded on the part. Some casting numbers can be ink stamped while others are printed on paper, which is then wraped around the part.
