Bronco II Ford Bronco II
Whats a code 25?????
Old Mar 13, 2002 | 04:32 PM
Slider28's Avatar
Slider28
I got a code 25.... what is that??>?? my hanyes book doesnt say.
then again, my haynes book hasnt help me one bit... shows a pic of the EVR and it says its the map sensor.... ALLLLLLL this time i thought i chnaged the map sensor! PFT! I SUE!!! J/K..
any help would be appreciated...
thanks,
chaz.
Old Mar 13, 2002 | 04:39 PM
Slider28's Avatar
Slider28
Might help if i told ya what it was off of. 86 bronco II 2.9l
Old Mar 13, 2002 | 09:54 PM
dreece's Avatar
dreece
>doesnt say.
>SUE!!! J/K..
>thanks,
>chaz.
Check out:
http://www.dalidesign.com/hbook/eectest.html
Old Mar 14, 2002 | 06:19 AM
TowerMaster's Avatar
TowerMaster
25 R Knock not sensed during Dynamic Response test
Old Mar 14, 2002 | 09:21 AM
Slider28's Avatar
Slider28
Nothing to worry about then???
CHAZ.
Old Mar 14, 2002 | 08:53 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Slider, actually it means that the computer isn't getting a signal from the knock sensor during the test. The sensor must be bad, or there is a bad wire connection going to it. If you are experiencing pinging, then check the wireing to it first.
Old Mar 15, 2002 | 02:45 PM
Slider28's Avatar
Slider28
I dont hear no pinging.... could a bad sensor make my B2 hesitate on acceleration?
chaz.
Old Mar 23, 2002 | 07:06 PM
4 Jaw Chuck's Avatar
4 Jaw Chuck
During the test you are supposed to give the block a whack with a hammer to simulate a knock, if you did not do this you will get the code. Try it again while doing the test and give her a couple of whacks (not to hard!) and see if you get the code.
Old Mar 23, 2002 | 08:51 PM
84broncoII4x4's Avatar
84broncoII4x4
