Sponsored by: Kumho
Brake Push?
Old Sep 27, 2004 | 09:37 AM
Saurian's Avatar
Saurian
Brake Push?
I'm getting a very severe push to the right in my truck. I just got it, and it didn't do it when I got it. When I hit the brakes, the truck wants to push hard to the right. I also have a pretty good squeak in them, too. Any ideas? Maybe my left brake pad is shot or something? Or the right is sticking...or clamping harder.
It did this AFTER moving a 5000+ and 3000+ load.
Old Sep 27, 2004 | 09:56 AM
paragod's Avatar
paragod
Maybe a caliper slide sticking? Also what year and make? It might be a proportioning valve malfunction. One other thing. Is the squeal constant, or just when you hit the brakes? If it is constant, you might have a stuck caliper or slide. If not, I would look to the proportioning valve.
Old Sep 27, 2004 | 04:57 PM
Saurian's Avatar
Saurian
Just at part brake application. At full application it doesn't squeak.
It's a 94 F150 302 5-speed supercab flareside. I don't know a whole lot about brakes...Others parts sure, but not brakes....
Old Sep 27, 2004 | 10:01 PM
paragod's Avatar
paragod
I would pull the calipers off and clean the slides real well and re-grease them. They can cause your brakes to pull and drag. A bad proportioning valve or collapsing brake hoses can cause similar symptoms. Check this thread:
https://www.ford-trucks.com/forums/s...d.php?t=287686
When you pull the calipers, check the pad wear. As you probably know, most newer pads have "tweeters" on them, (a small piece of metal on the side of the pad that contacts the disk when the pad wears) which can cause the squeal you are describing. Of course, pads worn to the point of metal-metal contact will cause a squeal or a grinding sound, so check pad wear on both sides.
Old Sep 28, 2004 | 10:19 PM
Saurian's Avatar
Saurian
I'm going to take it into a tire/brake place after I get home from my trip to California - don't want to deplete my funds completely before hand.
I hope its not too much, hopefully just needs the calipers regreased or whatever. I'd like to not have to pay for new calipers and all that junk. Don't know when the pads were changed last though...
..I'd rather have my pads grind without the "tweeter" thing, personally. I HATE squeaks on my vehicles.
Old Sep 29, 2004 | 01:55 AM
paragod's Avatar
paragod
Tweeters are a great selling tool for the auto parts stores, but they also give you a heads up when your pads are getting low.
Old Sep 30, 2004 | 12:37 AM
Hypoid's Avatar
Hypoid
That's quite a work out!
Grease or oil on the linings (bad seal) would cause it to pull to the side with the problem. Check your backing plates for weepage. While you're under there, look everything over to be sure nothing is out of place.
rock2610d
Sep 28, 2015 10:17 PM
anthonym92
53
Sep 8, 2015 02:15 AM
Pro DIY
Jan 28, 2012 06:28 AM
ztodd377
Jan 17, 2011 01:37 PM
Green Giant
May 24, 2009 09:03 AM
