Cruise Control Not Working
Old Jun 29, 2015 | 09:32 AM
rock2610d's Avatar
rock2610d
2000 4X4 V10 EXCURSION XLT with Hydro boost brakes.
1st I figured it was the brake pressure switch on the master cylinder. So I waited to fix it until I got my new hydro boost system installed with a new brake switch. DANG Cruise still does not work.
SO:
The cruise light in instrument cluster comes on when you push the "ON" button for cruise.
Nothing else happens when the set/accel, resume, or coast is pushed.
I did the procedures in:
https://www.ford-trucks.com/forums/9...ml#post8315477
RESULTS:
the cruise light flashes once when the "on" switch is pushed
ZERO FLASHES when all other buttons are pushed.
If I try pushing the "on" button again during the test no flash....but it does flash once at the start of the test.
So I guess its the servo, or right side switches??
Suggestions?
Old Jun 29, 2015 | 11:38 PM
3cv's Avatar
3cv
does the horn work? if that doesn't work as well check fuses.
Old Jul 1, 2015 | 06:42 PM
rock2610d's Avatar
rock2610d
I inspected the servo and it is severely corroded and must have gotten water in it at some point as it was cracked too.
Put a used servo in and cruise works now but the odd thing is the light in instrument panel does not light up at all now.
What could cause that!!!
Old Sep 28, 2015 | 07:32 PM
centurion2's Avatar
centurion2
Cruise control
Where is the servo you replaced for the cruise control?
Thanks, Centurion2
Old Sep 28, 2015 | 10:17 PM
rock2610d's Avatar
rock2610d
Thanks, Centurion2
In engine compartment on passenger side fender, next to battery. It has a black plastic coated cable coming out of it that goes to throttle body.
westcar360
Oct 19, 2019 06:45 AM
GGstar
Nov 21, 2015 10:38 AM
49 Ford F-1
Jun 7, 2012 10:03 PM
bruno2
Aug 29, 2011 06:13 PM
