spread bore/square bore
Old Sep 26, 2004 | 08:56 AM
FORD60's Avatar
FORD60
hi, newbie here ,ive got a simple question ,will a square bore carb with a one inch aluminum riser (edelbrock 750),work correctly on a spreadbore intake ,is there any kind of adapter made? thank you very much!
Old Sep 26, 2004 | 11:06 AM
Homespun91's Avatar
Homespun91
A simple question, but not necessarily a simple answer. There's a lot of things to consider such as hood clearance, mixture distribution, throttle linkage, etc. etc. etc., but the short answer is, yes, it will work on a spreadbore intake, & yes, there are adapters available. I assume you are installing the E-brock on a stock intake; you might also look at the Holley 650 & 800 Vacuum secondary spreadbores, if you plan to keep this intake permanently. Also, make sure your throttle/trans linkage doesn't bind & is able to open the carb all the way at full pedal travel. Good luck & welcome to the board!
Old Sep 26, 2004 | 03:40 PM
Brad Johnson's Avatar
Brad Johnson
Holley used to make a square bore to spread bore adapter plate. If they don't still make them you could probably pick one up at a swap meet or on ebay.
Brad
Old Sep 26, 2004 | 08:02 PM
Breeze's Avatar
Breeze
Mr. Gasket used too (probably still do also) make one that you could use to install a square on a spread. They ran about $15 or so at Autozone and such
Old Sep 26, 2004 | 08:43 PM
FORD60's Avatar
FORD60
re square bore/spread bore
thank you guys ,for the help,this web site is awsome,i tried it and it worked! junkyard motors arent all that bad after all! thanks
Old Sep 26, 2004 | 10:01 PM
bassdude's Avatar
bassdude
i did this exact thing today. i found a almost new Q-jet at the pick your part yard today $20.00. got an adapter from checker for $20. it's in and works good. $40 bucks total for a new carb.
Old Sep 27, 2004 | 01:06 AM
getuted's Avatar
getuted
Lightbulb
just a quick question, a square bore is the one with the 4 same size ports arn't they? spread bore have the 2 big ports and 2 small ports?
Old Sep 27, 2004 | 09:07 AM
mark a.'s Avatar
mark a.
Yes .......
Old Sep 28, 2004 | 02:29 AM
getuted's Avatar
getuted
thanks for that, its been a while...... and it shows..... trust me
Jay94250
13
Jul 31, 2024 06:55 AM
GeneGregory
May 24, 2015 10:25 AM
Speedjester
Ford Truck Parts for Sale
Dec 12, 2014 11:35 AM
TexinCali
Dec 2, 2013 01:47 PM
lance65
Sep 3, 2013 07:41 AM
