Offroad & 4x4
Will these be enough?
Old Sep 23, 2004 | 05:34 AM
wyldstallyn73's Avatar
wyldstallyn73
You might want to check out a fan from a Taurus/Sable, they move a LOT of air and I have run them for years in a couple of different vehicles and never had a problem with just a toggle switch, but I use the heavier style switch. try not to get water or mud inside the motor of these fans, they dont tolerate that very well, but I doubt any of them would.
Old Sep 23, 2004 | 11:43 AM
monsterbaby's Avatar
monsterbaby
well mine have seen alot of mud and water when they were on the 86 with no problems of coarse I don't have that problem now.
I measured them and they are 24" at the widest point, and 15" tall, the fans are 10", and 12" diameter.
Old Sep 23, 2004 | 12:23 PM
82F100SWB's Avatar
82F100SWB
The 3.8l Taurus/Sable fans are the fan of choice. 2 speeds, and move something like 5000 CFM on high... You DEFINATLEY need relays... Said fans draw 80 amps on startup... 2 45 amp relays in Paralell is what Ford used for them...
Old Sep 23, 2004 | 12:55 PM
monsterbaby
Are the taurus fans shrouded type or just open fans, that seem like they would definatly be good setup though if you can find them, most of them I looked at were gone, or they had the 3.0 in them. I do like the 2 speed idea.
Old Sep 23, 2004 | 11:55 PM
mustange70's Avatar
mustange70
Yeah i believe in the one yard i will be going to to pick up this 9", i know that there are several tauras/sable sittin in the, and that idea of a 2 speed fan is pretty neat thing to have. As for those dyansti fans they seem like they won't cover the bottom 6 or so inches of the rad, but i think it'll depend on what i can find when i go up and also what will fit the rad the best.
Old Sep 24, 2004 | 05:02 AM
wyldstallyn73
The taurus fans are shrouded.
CdnWillyG
13
Aug 21, 2020 04:35 PM
topfuel
Aug 18, 2013 10:37 PM
f1001969mike
Oct 17, 2012 11:26 PM
boaterbob
Dec 7, 2010 07:31 AM
46069dord
16
Sep 9, 2008 10:44 PM
