Fan thermostat
Old Dec 6, 2010 | 09:14 PM
boaterbob's Avatar
boaterbob
Fan thermostat
My truck came with an electric fan with just an on off switch. Since i'm in the process of wireing i want to put a thermostat on it. They have the type with the probe that pushes into the rad fins. Also the unit withthe sender that goes into the manifold. I already have a direct mechanical guage in that hole. Any recomendations on which type to go with?? Never used one of these before always went with the fan clutch.
Old Dec 7, 2010 | 07:26 AM
skuzzel_butt's Avatar
skuzzel_butt
i used this one from speedway
Electric Cooling Fan Controls
worked real well. fully adjustable. uses the gauge as the sender.
joe
Old Dec 7, 2010 | 07:31 AM
sdetweil's Avatar
sdetweil
I'm using the same one as Joe, bought from Ebay. Mine uses the manifold sender to trigger the built in relay.
I direct power the fan from the battery via a second relay, so this switch turns on the second relay. (keeps power load out of the main fuse panel, along with air bag pump, fuel pump and headlights)
Sam
BRay09
Sep 8, 2013 09:30 PM
abyars111
Jul 28, 2013 07:46 PM
grimace71
May 9, 2007 09:45 PM
95Bronco 4x4
1978 - 1996 Big Bronco
Dec 23, 2003 08:03 PM
4xFordFreak
1983 - 2012 Ranger & B-Series
Aug 14, 2003 08:38 PM
