engine not right
Old Sep 22, 2004 | 07:55 PM
djd19852004's Avatar
djd19852004
Angry engine not right
my 58 f 150 was doing just fine until bout three days ago then it started acting funny when i start it and let it idle for a while it seems to flood does any one know why this would happen
Old Sep 22, 2004 | 09:36 PM
Lee Lichterman's Avatar
Lee Lichterman
First off, do you realize you are in the 80-86 trucks and not in teh older section?
First guess would be a sticking choke. As it heats up, the choke should be opening to let the truck run more lean but if yours is sticking, that will flood it.
Could be mechanical or as simple as spraying it with carb cleaner if it is gummed up.
What motor? Stock? Old carburated or beefed up after market 4 barrel?
Lee
Old Sep 29, 2004 | 10:43 AM
djd19852004
ive go a stock 302 with a stock 2 barrel carb i found out the float and seat were bad but now i have a vacuam problem
B1GKAHUNA
Jun 15, 2014 02:05 PM
equine_21
Jan 15, 2003 04:14 PM
Redneckerson
Mar 15, 2002 07:49 PM
mrshorty
Feb 28, 2002 04:18 PM
Pastmaster
Dec 4, 2001 04:36 PM
