351w no start
Old Mar 14, 2002 | 04:05 PM
Redneckerson's Avatar
Redneckerson
351w no start
Old Mar 14, 2002 | 06:50 PM
Crewcutland's Avatar
Crewcutland
351w no start
I have a 88f350 with a 351w efi, the cab was really rusty so I replaced the cab so that involved pulling the wire harness, I put the cab on and put the all the wires back in but it won't start, I can jump the solenoid and it will crank but when I turn the ignition it lightly ticks from the relays, before I was having a problem with it not starting but I could always here the fuel pump turn on and then I was able to jup the solenoid and it would start. now when you turn the ignition you can't here the fuel pump. Any answers will help
Thanks a million,
Old Mar 14, 2002 | 06:55 PM
Phillip Guidry's Avatar
Phillip Guidry
351w no start
did you reuse your original steer column ? does the engine light come on when you turn key to the run position ? you may have a broken actuator or a bad/loose ignition switch.
Phil
Old Mar 14, 2002 | 10:36 PM
Crewcutland
351w no start
The check engine light comes on a you can hear 3 clicks from the relays on the left fender well. Still can't hear the fuel pump turn on. thanks
Old Mar 15, 2002 | 07:49 PM
Phillip Guidry
351w no start
ok, so even if you put the key in the run position, jump the starter solenoid, it still wont fire up ? i have an 88 model and never do hear any of the fuel pumps turn on, neither the frame mounted nor the tank mounted. if you were hearing the fuel pump (s) before, it could 've been a sign it was on its way to complete failure, so check for voltage at fuel pump (s) when you first turn the key to run (get a helper to turn key while you hold test light,you only got a few seconds before the computer quits sending juice). regardless of what you find with the fuel pump electrical test, you must fix the problem with no crank from key switch,whatever it may be, and you may solve both problems at one time .
phil
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
