Remote Start - recommendations
Old Dec 2, 2001 | 08:51 PM
Pastmaster's Avatar
Pastmaster
Old Dec 4, 2001 | 09:43 AM
bdonalds's Avatar
bdonalds
1992 F-150 XLT 4x4 302
I am considering installing a remote start module on my truck and was wondering if anyone could recommend a brand. Also, what kind of modifications would have to be done to install one? I don't have any security system...heck, if you want to steal my truck, let me know and I'll send you my address and leave the keys in it!
Also, a bit off topic, I was going to get one for my girlfriend as well, she has a 98 or 99 Dodge Avenger, no security, but it is leased...anyone know what the implications of this mod on a leased vehicle is?
thanks,
Bryan
Old Dec 4, 2001 | 10:22 AM
kioolt's Avatar
kioolt
I've had good luck with Design Tech remote starters. One of them has been installed since late 94 and is still working fine. I seldom start my truck with the ignition switch anymore. Since you don't have a security system you won't need any special installation instructions.
http://www.designtech-intl.com/
Old Dec 4, 2001 | 10:23 AM
rabidranger's Avatar
rabidranger
I JUST had the DEI 552T remote starter with remote locks installed on my 97 F250. Circuit City did the install for me. I thought about doing it myself, especially after the sales guy told me there was no way the average joe could do it. Well after reading the book, he was almost right. The installation guru at the store took 4.5 hours. I could have done it myself, but it would have taken at least the weekend, and several trips aback and forth to the store! So for $70 more I let them do it. ANYWAY... I like the system so far, it has a 1000 ft range(!) 2 remotes, keyless entry, hood pin lockout to disable the ignition system should someone open the hood and a slew of dealer programmable features; like runtime after start, door lock when shifted into gear, etc... Overall a nice system. Can even be upgraded in the future to include an alarm system. Made by the same company that makes Viper and Python systems. Retails for like $100 without installation.
Old Dec 4, 2001 | 01:42 PM
charlez's Avatar
charlez
I like the Crimstopper 900ER. I have installed 2 of these systems, one in my bros SuperCoupe and one in my Cougar. I like this one because of the great range. It has longer range than any other unit I have used mainly because of the real antenna instead of just a wire.
I would put one in my F150 except it's a 5spd. (still workin on it)
http://www.crimestopper.com/index2.html
http://www.crimestopper.com/coolglowtx1.jpg
http://www.crimestopper.com/rs900erCoolGlowA.jpg
Old Dec 4, 2001 | 01:54 PM
bdonalds's Avatar
bdonalds
So any comments from anyone who installed their own? I'm a quite stubborn do-it-yourself-er...
I read a manual on line for one model, and it looks like the only hard part will be finding the proper wires to connect the harness to.
Bryan
Old Dec 4, 2001 | 04:35 PM
kioolt's Avatar
kioolt
If you get just the remote start it not all that hard. Most of the wires are at the base of the steering column. You do run some power wires directly to the battery. There's a wire going to the brake light switch. Another to a hood pin switch. One to the tach input (you don't have to have a tach). There's a manual cut off switch.
If you get one that is a keyless entry/alarm/remote starter, you have to hook up a lot more wires.
Old Dec 4, 2001 | 04:36 PM
kioolt's Avatar
kioolt
To give you an idea of what's involved to do it right look at this.
Close this Window to Return to Listing
DesignTech International, Inc. - Web Support
Lincoln
MARK VIII
1993-1995
Remote Starter Wiring Colors and Notes
Function DTI Color Vehicle Color Location
Start: Yellow RED/LIGHT BLUE (MAY BE 2) - IGNITION SWITCH HARNESS
Ignition #1: Blue RED/LIGHT GREEN IGNITION SWITCH HARNESS
Ignition #2: Green GRAY/YELLOW IGNITION SWITCH HARNESS
Ignition #3: Wht/Blk BROWN IGNITION SWITCH HARNESS
Accessory: White BLACK/LIGHT GREEN IGNITION SWITCH HARNESS
Brake Light: Orange LIGHT GREEN (+) SWITCH ON BRACKET ABOVE BRAKE PEDAL
Tach Signal: Green TAN/YELLOW PIN 2 AT IGNITION CONTROL MODULE *
Parking Lights: Yellow BROWN (+) @ HEADLIGHT SWITCH OR DRV KICK PANEL
Headlights: Yellow RED/YELLOW (+) HEADLIGHT SWITCH OR BEAM SELECT SW.
OEM Alarm Disarm: Brn/Wht DARK GREEN/PURPLE (-) IN EITHER KICK PANEL
OEM Alarm Arm: n/a N/A
Diesel Glow Plug: Red/Black
Clutch Bypass Wire: n/a
Notes:
* Ignition Control Module Located On Rear Of Driver Fenderwell (93) Or Driver Front Of Engine Compartment (94) Or Left Hand Side Of Engine Compartment To Right Of Master Cylinder (95).
Lincoln
MARK VIII
1993-1995
Alarm and Keyless Entry Wiring Colors and Notes
Constant +12 Volts: Red 2 YELLOW AND 3 BLACK/ORANGE - IGN. SWITCH HARNESS
Starter Kill: Vlt or Wht RED/LIGHT BLUE (MAY BE 2) - IGNITION SWITCH HARNESS
Ignition +12 Volts: Orange RED/LIGHT GREEN IGNITION SWITCH HARNESS
Dome Lights/Superv: Brown BLACK/LIGHT BLUE (+) COURTESY LT OR GRAY (-) AT PIN SW.
OEM Horn: Blue YELLOW/LIGHT GREEN (-) STEERING COLUMN HARNESS OR AT RELAY
Power Lock: Wht/Red PINK/YELLOW DRIVER'S KICK PANEL **
Power Unlock: Yel/Red PINK/LIGHT GREEN DRIVER'S KICK PANEL **
Trunk Release: Grn/Wht PURPLE/YELLOW (+) RELEASE SW. OR DRIVER KICK PANEL
Alarm Input Wire: R/W or Gy/Bk BLACK/LIGHT BLUE (+) COURTESY LT OR GRAY (-) AT PIN SW.
Notes:
** Without OEM Keyless Entry See Note #203 - Reverse Polarity Door Lock Diagram, With OEM Keyless See Note #202 - Positive Pulse Door Lock Diagram.
Tel: (703) 866-2000 Fax: (703) 866-2001
©2001 All Rights Reserved
7955 Cameron Brown Court
Springfield, Virginia 22153 USA
1-800-DESIGNTECH
(1-800-337-4468)
DesignTech disclaims any liability or responsibility arising out of any inaccuracies of this
information or use of this information for installations or otherwise.
It didn't paste as good as I would have liked it. But you should be able to get the idea.
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Oklahoma Chapter
Apr 11, 2003 10:33 PM
walterdanek
16
Feb 16, 2001 07:56 PM
