Fuel Pump?
Old Nov 23, 2004 | 10:32 AM
  #31
gatesj's Avatar
gatesj
Yes, that's the fuel pump and that's what you need to replace. The top plate, float assembly and stainless lines are something you remove from the old one and put on this part before you put the whole thing in the tank. You have to solder or crimp the wires that you see in that picture to the wires attaching to the top plate.
I'm assuming you've already tried changing the fuel filter and verified the fuel pressure regulator is OK, or you have a situation where one tank makes the truck run well and the other doesn't. Keep in mind kinked lines too. I changed a tank out, truck wouldn't run much above idle, so I changed the pump. Same story and I had a gauge problem. I had the tank in and out several times before I found that every time I had put the tank up I had kinked the line coming out of the pump and seriously limited the amount of fuel volume that it could pump. Just something to think about before you go and drop all that cash for a new pump.
Old Nov 23, 2004 | 03:08 PM
  #32
DAAJR's Avatar
DAAJR
I just finished this job on my truck the picture from mike L is the fuel pump itself.
You have to remove the sending unit and conecting lines from the old pump.
Sending unit uses 2 screws to attach. the connecting lines slide in/out of the holes
on top. my kit came with a plastic wedge with an notch that slipped around one of the connecting lines. a little pressure on the wedge and lines come right out.
You might bend lines if you try to pull straight out.
daajr
BTW my straps were fine but had rust under them that turned into
a leak when I cleaned them up.
Old Nov 23, 2004 | 05:56 PM
  #33
moose94's Avatar
moose94
You guys have been so much help. Thank you very much I appreciate it. I took the truck to my mechanic he is going to handle it because I have to work everyday. But thank you very much for your replies and I have learned so much about my ford that will help in the future. Thanks again.
Old Jun 30, 2005 | 12:03 AM
  #34
beast86f150's Avatar
beast86f150
fuel problem
i have an 86 f150 that was a 5.0 fuel injection with two tanks but i put a 351w with a carb on it.. i want to continue to use both tanks.. i know that i need to get a universal 3 port switching valve. i don't think my sendors work tho because gauge reads full on both tanks yet they aren't.. i'm cathing hell trying to find a vendor that carries old style fuel sending units for standard mechanincal gas engines.. anyone with any help please share.. e-mail is bullkram@yahoo.com
Coccyx
28
Feb 3, 2019 07:28 PM
f100beatertruck
Feb 15, 2012 10:22 PM
websthes
Sep 11, 2007 09:39 AM
jade79
Aug 25, 2007 03:32 PM
Galford
1983 - 2012 Ranger & B-Series
Apr 7, 2003 06:30 PM
