Old Sep 20, 2004 | 11:09 PM
j30rdesign's Avatar
j30rdesign
Anyone know were to find a 289?? everyplace I call or find on the internet seems to mistake me for wanting a 302.
Old Sep 20, 2004 | 11:27 PM
ktpdc's Avatar
ktpdc
i think they stoped 289s in like 70 or so.. so it might be hard to find. junk yard maybe
Old Sep 21, 2004 | 08:12 PM
P51D Mustang's Avatar
P51D Mustang
The 302 replaced the 289 in 1968. It's really almost the same motor, as the 302 is a stroked 289. The stroke on the 289 is 2.87 inches. The stroke on the 302 is 3.00 inches. The pistons are the same, but the 289 rods are 5.155 inches long, and the 302 uses 5.090 inch long rods. The 289 had slightly less stroke, but a slightly better rod/stroke ratio of 1.84, compared to 1.699.
The 302 used a slightly improved block, with longer cylinders for improved piston stability, and it also had better flowing water passages, for better cooling. The 302 block is actually a better block, but both the 302, or the 289 bottom ends, can be used in either block. Later 302's didn't use a two piece oil seal , but I'm unsure of when the change was made.
Old Sep 23, 2004 | 11:43 AM
J30R's Avatar
J30R
so bassically i could use a 302 block with 289 innerds??
if so that would be great.
I have the 289 innerds but bad block accually horrible block
Old Sep 23, 2004 | 05:04 PM
P51D Mustang
Yes, that's correct, as long as the crank and block are designed to use the same rear mains seal. You may have to check on that. Some blocks used two peice seals, and late model 302's switched to one peice rear seals later on. As long as the crank journal, at the seal, is the same, it's just a matter of matching up the seal to the block, and cap. But diffinately take some measurements. Later 302 blocks also have a hole for the dipstick tube on the drivers side of the block, that the early 289's and 302's didn't have.
Old Sep 23, 2004 | 07:02 PM
j30rdesign's Avatar
j30rdesign
ok thanks for all the help!!!!
speeddemon289
1947 and Older Ford Trucks
Jun 2, 2005 12:59 AM
Orange Crush
Offroad & 4x4
Apr 19, 2004 10:09 PM
yak
Sep 3, 2003 11:36 PM
cams69
Jun 27, 2001 11:10 AM
RAILMAN
Sep 5, 2000 02:48 PM
