Offroad & 4x4
lower gearing
Old Apr 18, 2004 | 11:54 PM
Orange Crush's Avatar
Orange Crush
lower gearing
Want to put a 6.32 to 1 t-18 behind a 289 ford v8 any ideas where I would find the correct bellhousing? What years did ford put a 289 or 302 with a t-18 or t-19 transmission?
Old Apr 19, 2004 | 01:26 AM
rlh's Avatar
rlh
late 70s and 80s, Ford used the T18 and T19 (relatively hard to find) behind 302s. That's some serious gear reduction. Are you planning to run a 205 and twin stick it?
Old Apr 19, 2004 | 12:20 PM
teds74ford's Avatar
teds74ford
You can use the same bellhousing from a 300 or a 351W too. I would look in the 80s trucks, since they used the correct bellhousings since they ran these engines.
Old Apr 19, 2004 | 12:52 PM
proeliator's Avatar
proeliator
T19s are harder to find indeed. Externally you can id them by the extra pto port. Different gearing and synchroed first but just as stout as the '18. I prefer the np-435s.
Old Apr 19, 2004 | 04:56 PM
bremen242's Avatar
bremen242
If you are looking for a t-19, you're only going to find them behind 460 powered f-250s (and I believe f-350s).
If you want a np435, you can find them in almost any 4x4 manual F-150s built in the early 80s.
And I'm pretty sure you can interchange any SBF bellhousing regardless of the tranny.
Old Apr 19, 2004 | 10:09 PM
hoxiii's Avatar
hoxiii
I can find one in my backyard if you're interested SBF manual bellhouing that was behind a 300 w/ a mechanical clutch and in front of a T-18.
Justin
dogstar
21
Nov 11, 2010 12:39 PM
ejam65
13
Sep 19, 2010 06:12 AM
ps91368
Sep 11, 2006 12:43 AM
1972ford_f-100
May 4, 2004 08:48 PM
Orange Crush
1966 - 1977 Early Broncos
13
Apr 30, 2004 06:30 AM
