starter help
Old Sep 20, 2004 | 08:33 PM
matt77F2504x4's Avatar
matt77F2504x4
starter help
my starter or solenoid just went out today. tried to turn the engine over and it clicked like it was trying to grab, then tried again and it just whirred.
is this my starter or the solenoid. the solenoid is only a month old(replaced it because it looked old and was cheap) and the starter has about 9,000 miles on it. if someone can give me some advice tonite it would sure help.
Old Sep 20, 2004 | 09:20 PM
Dealford's Avatar
Dealford
The "whirr" sound that you hear is likely only the starter motor spinning without the bendix kicking out the gear to engage the flywheel.
The solenoid is just an electromagnet of sorts and only makes clicking sounds, not "whirr".
AL.
Old Sep 20, 2004 | 09:34 PM
Franklin2's Avatar
Franklin2
If the whir noise is the starter, then your bendix or gear assembly on the starter is probably bad. It has a one-way clutch bearing in it so the starter can turn the engine, but the engine can't turn the starter. They go out sometimes.
Old Sep 20, 2004 | 10:01 PM
Muffinman's Avatar
Muffinman
Bad Bendix, If your engine backfires or locks up from fluid lock some times it breaks it when trying to start it.
Just go get the parts to rebuild it, all the "Parts" Bushings front and rear, Bendix, Brushes, and solenoid cap. Make sure you sand the armature down and under cut it about a 1/16" between the windinds where the brushes seat.
Old Sep 20, 2004 | 10:53 PM
matt77F2504x4
i dont want to get the autozone starter, but they are the only ones open. it's only going to cost me 30 dollars, so if it lasts a year i'll be happy with it. by the way, i do have some run-on, so that may be what broke the bendix.
thanks for the help guys!
Old Sep 20, 2004 | 11:04 PM
Muffinman's Avatar
Muffinman
Those cheap rebuilds scare me. They will leave you out in the boonies at the wrong time.
If you just want to get it up and running, Just buy a Bendix and grease the shaft and slid it on.
Old Sep 21, 2004 | 02:28 PM
matt77F2504x4
what are the good brands? i would rather buy two than put one in on a cold night on the roadside.
it was the bendix, it was completely obliterated. i had to clean out chunks of it from the bellhousing. where do the chunks i couldnt reach fall to? are they going to damage my flywheel?
Old Sep 21, 2004 | 03:40 PM
Muffinman's Avatar
Muffinman
They flew out the opening in little chunks.
I don't know any name brands other then what a dealer sales. Just make sure you put those shims back the way they came off.
Old Sep 21, 2004 | 05:32 PM
Franklin2's Avatar
Franklin2
Be careful with the grease. If it gets really cold where you live, the grease gets too stiff and won't let the gear slide out to meet the flywheel.
Old Sep 22, 2004 | 03:06 PM
matt77F2504x4
muffinman, my new starter didnt come with shims and none came off with the old one. if there were any shims on the bellhousing they stayed right where they were. i hope its in position; it seems to start perfectly now.
fordatic
Sep 23, 2016 01:28 PM
Wdlynch
Apr 14, 2016 07:10 AM
granny_rocket
Sep 23, 2015 04:39 PM
garretttt4
Jul 24, 2015 11:51 PM
74f2502wd
Dec 8, 2011 04:56 PM
