stick shift removal
Old Sep 20, 2004 | 10:28 AM
tomsrod's Avatar
tomsrod
stick shift removal
I'm looking for tips from anyone who has removed the floor stick shift on a 4 speed shifter. My Ford manual says to remove the shift boot and then depress and rotate the cap counter clockwise. I can't seem to get the cap to depress or rotate. The previous owner cut the shifter and then re-threaded it to accept a shift **** with large threads. I want to go back to original and have a replacement original shifter.
Old Sep 20, 2004 | 11:00 AM
smcafee's Avatar
smcafee
Those can be a real pain. Sometimes they just come off the way the book says, sometimes it takes two guys. One to depress the other to turn. Just keep trying. It does need to depress quite a ways. 3/16 to a 1/4 inch maybe. If yours' is not depressing at all, there may be some gunk in there fowling up the works. Every time I take one off I think about making a tool to drpress and turn. Try a little wd40 or other light lube in there to loosen it up. Good luck! Steve in Boise
Old Sep 20, 2004 | 12:40 PM
6t6merc's Avatar
6t6merc
A pain is right. When you have the retainer off look for any damage to the hook areas and clean them up with a file and maybe pliers.
Eric
Old Sep 20, 2004 | 12:54 PM
camperspecial65's Avatar
camperspecial65
What model tranny are you working with ???
Warners have a screwon cup and rod lifts right out, NP is the one thats a pain.
Old Sep 20, 2004 | 02:13 PM
Lazy Hog Farmer's Avatar
Lazy Hog Farmer
I"ve been down that road and here is what I did. I made a "u" shaped block of wood out of a piece of 2x4 that was long enough to fit between the lever retainer and a bottle jack that I placed between the wood and the under side of the dash. I protected the dash with a piece of rubber. A little leverage from the jack and the retainer will depress so that you can turn it. The block and the jack are a handfull and a second pair of hands would be usefull but I was able to do it by myself. Kind of backyardish but it works great. Good luck, Lazy
Old Sep 20, 2004 | 02:49 PM
Mike G's Avatar
Mike G
I just gave up and dropped the whole tranny out the bottom of the truck with the stick attached... My method was justified as the replacement is a C6
--Mike
Old Sep 20, 2004 | 07:35 PM
tomsrod's Avatar
tomsrod
stick shift removal
All good suggestions, but still no luck. I'm in the process of rigging something like lazy hog farmer suggested. Thanks to all and I'll keep you updated. It is the NP tranny and not a big enough issue to drop the tranny.
Old Sep 23, 2004 | 08:15 AM
tomsrod's Avatar
tomsrod
Smile
I was able to get the old shifter out quite easily last night. I enlisted a second pair of hands and was able to depress the retainer with two large screw drivers with small pieces of rubber on the tips to protect the cap. A good shot of PB Blaster loosened up the cap and it came off right away. Thanks to all who helped. That is what makes this site work.
leasesvc
Dec 27, 2020 11:10 AM
F350moneypit
15
Apr 3, 2017 11:08 AM
1956_F100
Mar 7, 2017 08:49 PM
jcam77
Jan 16, 2017 11:36 AM
als06ford
2004 - 2008 F150
Jan 15, 2012 03:02 PM
