1978 - 1996 Big Bronco
Help! Starting problem!
Old Sep 19, 2004 | 11:49 AM
Kaboom's Avatar
Kaboom
Hi all,
Drove the '94 for several hours last night- parked it and this morning she won't start- when I try and crank it, I hear the fuel pump turn on, and then a click as it tries to turn over, and then everything goes dead- all the accesories/lights go out. They stay out for a few minutes, and then they will come back on...same thing happens if I try to crank it again. I've put a voltmeter on the battery and it's showing 12v.
Any suggestions?
Thanks!
Kaboom
kaboom@digizip.com
Old Sep 19, 2004 | 11:57 AM
Manual5.0/96's Avatar
Manual5.0/96
My 96 did the same thing when the starter went out. Pull it off and take it to the parts store, most of them can bench test it for you.
Old Sep 19, 2004 | 05:34 PM
greystreak92's Avatar
greystreak92
Its either a starter or a lousy connection at one of the battery terminals. A weak connection or corrosion will be fine til the amperage draw of the starter motor tries to pull heavy amperage through it. Make sure you check the block end of the negative cable as well.
Old Sep 19, 2004 | 07:59 PM
Beast12's Avatar
Beast12
It is a loose/corroded battery connection. Clean your battery terminals really good and the places where the wires go too. Make sure your ground wire is clean. It is important! Good luck!
-Matt
Old Sep 20, 2004 | 07:45 PM
BOJOFASO's Avatar
BOJOFASO
dirty batery terminals. remove them and go buy a battery terminal cleaner and clean them real good. replace cables and cover them with dielectric grease and your problems should be gone.
Old Sep 20, 2004 | 10:39 PM
Kaboom's Avatar
Kaboom
You guys are right on the money- cleaned the battery terminals...it still wouldn't crank, though until I turned the headlights on and tried to crank it. It sounded like the silenoid was gone. Replaced the starter relay anyway.
kaboom10
Exhaust Systems
28
Nov 27, 2015 08:42 AM
grasfarmr73
Oct 29, 2015 04:27 PM
f100beatertruck
Mar 28, 2015 03:39 PM
kaboom10
1997 - 2003 F150
Feb 26, 2015 09:26 PM
mrbeefcake
Jun 24, 2003 04:01 PM
