leveling kits
Old Sep 20, 2004 | 03:37 PM
Maxium4x4's Avatar
Maxium4x4
Note: with the 35's and the Fabtech kit. The only rub was the front plastic under the bumper which I rounded off on the corner.....
Old Sep 20, 2004 | 04:56 PM
rjd04powerstroke's Avatar
rjd04powerstroke
i dont get why u think 325/70/16 will rub with a 2and a half lift in front but u say 315/75/16 dont. the 325's are a lot smaller 1 inch and only 1/2 wider than 315's man buddy ur black f350 with 3.5 fabtech looks real good is the back sitting lower than the front? or did u add a 1.5 add a leaf?
Old Sep 20, 2004 | 05:31 PM
Maxium4x4's Avatar
Maxium4x4
I run 315's with no problems the truck sets level. I know others may add on leaf to the spring pack in the rear. As my truck sets I only have the Fabtech 3.5 drop kit in the front.
Old Sep 20, 2004 | 08:03 PM
rjd04powerstroke
thanks for info just ordered the fabtech 3.5 hehe. mind if i ask u what u payed for it? i ordered it from 4 wheel parts performance center it was $600 but i wanted red shock boots i think they charged me for them not sure.
Old Sep 20, 2004 | 08:08 PM
supernewguy's Avatar
supernewguy
Hmmm, each truck must be different because I am running 305's on stock suspension with no rub whatsoever.
Old Sep 21, 2004 | 06:28 AM
Maxium4x4's Avatar
Maxium4x4
Well here we go....not sure what all you ordered.
FTS 424-1BK 3.5 SHACKLE LIFT 473.00
Shocks - 2 FTS 7265 and 2 FTS 7333 @ 35.06 TOTAL..140.24
RAN 1927 SHOCK BOOT @ 5.15 .......20.60
633.84 Total
Mine was from my local guy so with tax and shipping if you ordered pretty much what I have listed your in the ball park. I have more than listed here because I run the dual shocks all the way around.
Old Sep 21, 2004 | 06:33 AM
Maxium4x4's Avatar
Maxium4x4
What year is your truck? If it did not need a lift like my old 95 I sure would have not put one on my 03. You can fudge and shim the bumper out 1.5 inches but I opted not to on this truck.
Old Sep 21, 2004 | 04:27 PM
west tn 6.0 powerstroke's Avatar
rough country leveling kit by heckothorn off road
I live in northwest tn where the heckothorn off road company is located and have found that all of the trucks in this area are running the heckothorn leveling kit and all seem to love it. the prices are great right from the factory when you go and pick them up and trucks all around are running 315 and 305 with ease. I have a friend who has a levling kit and has put a set of american racing 17in wheels and a set of 315 bfg tko take off from a hummer and a 2 in block in the rear and all in all has equaled the height of a 4in lift. I love the way that the truck looks and drives and I can't wait to get my new tires and a kit installed.
Old Sep 23, 2004 | 08:53 AM
supernewguy
I have an 04 with FX-4 package. Did not have to shim or trim anything.
Old Sep 23, 2004 | 03:48 PM
rjd04powerstroke
no trimming but u were not running325/70/16 right?
Old Sep 23, 2004 | 03:57 PM
supernewguy
305/70/16 is what I am currently running
Old May 4, 2010 | 09:02 PM
AndeyHall's Avatar
AndeyHall
i see a few people are confused about their tire sizes when it comes to metric. I'd be glad to explain this: lets use the original 315/70R16 tire that was posted.
1. The first number is the width in millimeters - so a 315 would be 12.4 inches roughly when you convert it to inches.
2. The second number is a percentage in terms of the width (sort of). For this tire, the height from the top of the rim to the top of the tire (or the bottom of the rim to the bottom of the tire) is 70% of the width.
3. So to convert from metric to english, convert the width to inches, and that part is done. Then multiply the width by the percentage number (as a decimal, not the whole percentage). That gives you the height of one side of the tire, so you'll want to multiply that by 2, and then add the rim height. That'll give you your tire height. Sounds a little complicated but it's pretty simple.
Old May 18, 2010 | 07:17 AM
  #28
Scorpion2's Avatar
Scorpion2
Need Advice on auto leveling the rear of my 2011 F250
I just purchased a 2011 F250 Lariat. When I hook up my Toy Hauler the rear squats quite a bit. I can compensate a little with the weight distribution hitch, but would like to install an autoleveling system in the rear. What is my best option? If possible, I would like to soften the ride in the rear when unloaded also.
tozir
2004 - 2008 F150
Jan 15, 2015 03:24 PM
pin8246
30
Aug 2, 2012 08:25 PM
bryced_1
Jun 18, 2011 06:10 PM
onuredneck707
Feb 26, 2011 10:06 AM
redranger1
May 3, 2002 01:29 PM
