Sponsored by: Real Truck
leveling kit.
Old Apr 30, 2002 | 10:01 PM
redranger1's Avatar
redranger1
leveling kit.
what does the leveling kit do other then raise the front 2 1/2 inches? and what is the best brand? i am really thinkin about getting one of these kits fer my truck. just dot know what to expect.
-nathan
Old Apr 30, 2002 | 10:59 PM
Ghostrider304's Avatar
Ghostrider304
leveling kit.
I have a BDS leveling kit on my '01 F-250 PSD. It make a big difference over the stock look. It was about $400 and came with 4 shocks and all the mounting hardware.
If I had pics I put them up, but every time I think about picture the truck is a mess.
If I'm not mistaken their web site is WWW.BDSsuspension.com
FabTech also make a good kit, but its a little bit more money.
Hope this helps?
Will-
Old Apr 30, 2002 | 11:27 PM
redranger1's Avatar
redranger1
leveling kit.
[updated:LAST EDITED ON 01-May-02 AT 00:28 AM (EST)]does it raise the rear end up any?
-nathan
Old May 1, 2002 | 01:17 AM
Ghostrider304
leveling kit.
No. This kit only lifts the front of the truck. Some use add a leaf spring, the BDS uses longer spring hangers.
Aleveling kit gets rid of the nose down look of the stock set up.
And gives you more room for bigger tires.
If you use a kit that adds more leaf springs to the front you will change the ride, a spring hanger kit will keep the same ride quality.
Will-
Old May 1, 2002 | 01:39 AM
chadrock's Avatar
chadrock
leveling kit.
[updated:LAST EDITED ON 01-May-02 AT 02:42 AM (EST)]All the leveling kit does (if it is a hanger kit) is relocate where the leaf springs connect. I have a 3" hanger kit on mine. I have a few pics in my gallery under misc. pics (they are the big blue pieces in the last two pictures in that gallery). This kit will maintain the same factory ride. If you get a leveling kit that has additional leaf springs, the ride will change. And yes, the leveling kit only raises the front of the truck, hence, a leveling kit. You could get a larger rear block to raise the rear or additional springs. Hope this helps.
Old May 1, 2002 | 01:43 AM
Ghostrider304
leveling kit.
I see that your kit got rid of the second bumper on the bottom. Man I hated that thing.
Will-
Old May 2, 2002 | 08:40 PM
tex71's Avatar
tex71
leveling kit.
Old May 3, 2002 | 01:14 PM
MKJRH 00's Avatar
MKJRH 00
leveling kit.
This might be a stupid question, but would "riderite" airbags serve the same purpose, with the flexibility to control height?
Old May 3, 2002 | 01:29 PM
Yeti's Avatar
Yeti
leveling kit.
>control height?
I believe that the bags are desinged for the rear suspension, not so much for the front.
deeno360
2009 - 2014 F150
May 25, 2014 08:01 AM
Miller
2009 - 2014 F150
Jan 21, 2014 08:26 PM
SCBarger
1997 - 2003 F150
Oct 13, 2011 09:51 PM
jda1961
2009 - 2014 F150
Jun 5, 2009 07:27 AM
redranger1
Apr 25, 2002 05:08 AM
