1978 - 1996 Big Bronco
Engine Perches for 1979 Bronco
Old Sep 16, 2004 | 07:22 PM
ABuzzard's Avatar
ABuzzard
Hey this is my first post, but i am a strong fan of fords of this year, and have a yard full to prove it!
My question comes with a newly attained 1979 ford bronco that came with a seized 400CI. I would like to replace that with a 351 windsor, but need to find engine perches to match the frame. I am not sure whether small blocks came in these years of 4x4s so i am a little skeptical on looking too hard. Any info would be greatly appreciated.
Alex
Old Sep 16, 2004 | 07:49 PM
mark a.'s Avatar
mark a.
You would be better off putting a 400 in it.
Old Sep 16, 2004 | 08:27 PM
ABuzzard's Avatar
ABuzzard
No 400 for this guy
See i know it would be "easier" to put a 400ci back in. But so far in my experience with 400ci's i have broke a crank in half and taken out a connecting rod bearing, they are not my favorite engine. Now i have a strong running 351W i would like to put in. I will make perches if i have to, but would prefer to just find some. Which returns to the question on whether a 73-79 ford 4x4 came with a small block in it?
Old Sep 16, 2004 | 09:57 PM
mattri's Avatar
mattri
Not sure if this will help or not but I do know they came with the 300, which shares a lot with the small block V8's. The bell housing is the same and when going from a 400 to a 300 in my Bronco I had to scrounge different perches. So if the perches for a small block are the same as a 300 you should be able to find a set.
Old Sep 17, 2004 | 10:11 AM
oldhalftons's Avatar
oldhalftons
302/351W, 351M and 400 all use the same mount towers
Old Sep 17, 2004 | 10:13 AM
oldhalftons
the 300 perches are not the same. the 300 perches are actually the same as the 360/390 (not that they ever put a 360/390 in a 78-79 bronco).
Old Sep 17, 2004 | 05:57 PM
mattri's Avatar
mattri
Good to know, thanks.
grinnergetter
26
Jun 21, 2016 12:34 AM
julcan92
WTB - Parts & other
May 18, 2014 10:08 PM
Fordzilla80
Ford Truck Parts for Sale
Nov 22, 2012 08:28 PM
juchertf100
Jan 21, 2008 05:38 PM
r1brygo
Dec 4, 2003 05:18 PM
