HELP!!! Trying to locate 460 "front dress" and engine perches
Hello everyone.....New to the site. There is a lot of great info. here.
I am trying to locate all of the brackets and accessories for 460 that I am going to drop in my Bronco. Model year isn't that important, as I am willing to use V-belt pullies or serpentine drive. I also would like to find engine perches from a F-250 with a 460. Any help would be greatly appreciated!
I got mine here, they bolted right in, no problems.
http://www.broncograveyard.com/products/cat/20/130
Good luck on the brackets. I went thru H_LL getting everything lined up. Went thru 4 sets of brackets. Keep in mind that the 7.5 bolt holes are not exactly the same as the 460. Also you will run into different water pump and timing chain covers that have different hole locations.
r1brygo
These are what you need to mount the engine. Period.
They came down un-bid on. You could contact the seller and see if they still have them.
What year is your Bronco? If its an 80 up these will fit.
http://cgi.ebay.com/ebaymotors/ws/eB...ory=33613&rd=1
grinnergetter
26
06-21-2016 12:34 AM
shanes66charger
01-02-2012 10:10 PM
