disc brake conversion
Old Sep 15, 2004 | 05:50 PM
lemmy's Avatar
lemmy
I have a 73 econoline E200 with 4 wheel drum power assist. What do I need to convert to disc brakes and what years will work with this thing?
Old Sep 15, 2004 | 10:42 PM
Dennis460's Avatar
Dennis460
Talking
You'll need at least the spindles, the proportioning valve, and master cylinder(either manual or power, depending on what you van has) off a 73-79 F150. You can use the whole I-beam and radius rod assembly off the truck since they are the same size. You can also use the spindles of the 75 and up E150, but you'll have to swap sides.
Old Sep 16, 2004 | 10:31 AM
ClatonK's Avatar
ClatonK
Will this swap work on a 69 E200 with manual brakes as well. I think the later 2nd generation vans had some suspension differences. If this will work I will do this swap asap.
Thanks,
Clayton
Old Sep 16, 2004 | 08:59 PM
Dennis460's Avatar
Dennis460
Talking
Should work on any of the 68-74's
Old Sep 22, 2004 | 04:56 PM
lemmy's Avatar
lemmy
Ok, now what about the lug pattern? I've read that it's a different on than what I have on there now. I'd like to keep 'em all the same for rotation purposes.
Old Sep 22, 2004 | 11:26 PM
Dennis460's Avatar
Dennis460
The 68-74 E200's had the standard 5 on 5-1/2 bolt pattern, same as the newer E150's and F150's. So you won't have to chage anything.
Old Apr 16, 2006 | 06:48 PM
bruce69evan's Avatar
bruce69evan
hye , im new here , im wondering on the evan spindles it says 75 up , im wondering up to what year ?? thanks
Old Apr 18, 2006 | 07:05 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome bruce to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
mecone
1966 - 1977 Early Broncos
Apr 13, 2016 03:34 PM
FLJ
Sep 8, 2015 12:42 AM
Dskeet6
Apr 14, 2015 08:35 PM
pickle1280
Oct 13, 2014 08:05 PM
daman1953
Aug 11, 2014 05:08 PM
