9" Diff I.D.
Old Sep 15, 2004 | 01:49 PM
caddywhompus's Avatar
caddywhompus
9" Diff I.D.
I searched the forum looking for some kind of decoder the gibberish Ford puts on their Axle tags, but found nothing usefull.
I got a 9" rear end from an 82 Bronco that I want to swap into my truck. Curently, I have a 8.8 with 3.55 gears (according to my Ford build sheet).
Here's the code:
WFE-AW 0A08
3L50 9 S319A
Please help me decode this.
-Jimmy
Old Sep 15, 2004 | 10:33 PM
hotrodford87's Avatar
hotrodford87
It's a 3.50 ratio. The "L" between the 3 and 50 (3L50) means it as a limited slip.
Old Sep 16, 2004 | 08:48 AM
caddywhompus
Anybody know what the rest of the writing means?
And as for the 3.50 ratio, will that be compatible with the 3.55 ratio i have in the front axle? I know it's close, but is it close enough?
-Jim
Old Sep 17, 2004 | 01:21 PM
caddywhompus
anyone? (bump)
Old Sep 17, 2004 | 05:11 PM
85e150's Avatar
85e150
If you are only using 4WD in the sloppy stuff, it will be ok...... Your's isn't full time, right?
Old Sep 17, 2004 | 05:52 PM
RTM's Avatar
RTM
If you look up the front 44 gear ratio for both a 9 inch or 8.8 bronco you will find the front ratios are the same.
rocknrod
1997 - 2003 F150
Mar 1, 2014 01:05 PM
KillerTux
Oct 26, 2010 12:32 PM
97F250LD4X
Mar 26, 2009 03:41 PM
Fords&Farmalls
Aug 20, 2007 03:28 PM
Rizz0
Oct 14, 2003 07:37 PM
