1978 - 1996 Big Bronco
Dash Lights Not Working
Old Sep 15, 2004 | 01:44 PM
TxBrokenarrow's Avatar
TxBrokenarrow
Anyone Know To Get Dash Lights Operating Again???i Replaced Sockets And Bulbs..only Rt.turn Signal Works...can I Replace That Back Electrical Part That Looks Like Fiber Optics??or Replace The Dash Cluster???thanks
Old Sep 15, 2004 | 02:27 PM
Kemicalburns's Avatar
Kemicalburns
did you replace fuses?
Old Sep 15, 2004 | 02:46 PM
TxBrokenarrow
I'll Check That..if The Fuses Are Ok What Else Could It Be??
Old Sep 15, 2004 | 02:48 PM
Kemicalburns
have you tried the dimmer switch
Old Sep 15, 2004 | 02:54 PM
TxBrokenarrow
Yes That Works On Tack
Old Sep 15, 2004 | 03:00 PM
TxBrokenarrow
Chemicalburns, Were You Talking About The Hi Beam (blue Light) I'm Not Sure If It Works I Don't Drive Much At Night..
Old Sep 15, 2004 | 03:01 PM
Kemicalburns
no the headlight switch is also the dimmer switch. it twists clockwise to dime and counterclockwise to briten
Old Sep 15, 2004 | 03:04 PM
TxBrokenarrow
Yes That Works Tack Light Will Dim And Dome Light Will Dim Also
Old Sep 15, 2004 | 03:08 PM
TxBrokenarrow
How Hard Would It Be To Pull Dash Cluster To Look At Back..might Be A Plug Back There...my Heads Too Big To See Behind There...maybe Take Dash Pad Off??i Can Alway's Just Point Flash Light To Look At Guages...hello Come In
Old Sep 15, 2004 | 03:16 PM
mswamper's Avatar
mswamper
The light switch is a bit of a problem on mine. Pulled out full- no dash lights, Pulled to park light position- dash lights work, pulled to just past park light position where head lights come on- dash lights work. This is a new switch also.
Old Sep 15, 2004 | 04:06 PM
TxBrokenarrow
Just Got New Lmc Catalog..they Have New A Printed Circuit Board For $99.95 P/n 49-6276 But What's Up With The Voltage Stabilizer P/n 47-0894 For $39.95..i Wonder How You Can Tell If It's Any Good??
PaulTMurphy
15
Dec 19, 2019 10:22 AM
lindazman
Dec 7, 2015 06:35 PM
irlfan360
17
Jun 3, 2015 01:18 PM
thunderbirdcakes
Aug 7, 2012 04:53 PM
ENGINENUT
16
Jul 22, 2009 04:16 PM
