Airbag light flashing?
Old Sep 14, 2004 | 12:17 PM
mickf66's Avatar
mickf66
Question Airbag light flashing?
What could be the cause for my airbag light to be flashing on my dash?
Thanks and God Bless!
Mick
'94 F-150 Extended Cab 4x4, 5.0L, 113k mi
Old Sep 14, 2004 | 01:18 PM
Franklin2's Avatar
Franklin2
It's got a problem. But I don't know the codes.
Old Sep 14, 2004 | 08:11 PM
Dealford's Avatar
Dealford
When you turn the key on & the light starts flashing, count the number of flashes. There will be 2 groups of flashes separated by a short pause. 3 flashes, pause 2 flashes is a code 32.
Count them off & post the number & someone will be able to help you.
AL.
Old Sep 19, 2004 | 08:19 PM
mickf66's Avatar
mickf66
I see...
The code is 32. Any thoughts anyone?
Thanks!
Mick
Old Sep 20, 2004 | 12:24 PM
Franklin2's Avatar
Franklin2
Here's a thread a little below yours. They say it's a bad clockspring behind the steerng wheel that may be causing it.
https://www.ford-trucks.com/forums/s...d.php?t=280205
Old Sep 20, 2004 | 10:22 PM
mickf66's Avatar
mickf66
Thanks for the help!
Mick
Old Sep 21, 2004 | 12:19 AM
albertafarmer's Avatar
albertafarmer
Question Air bag
I have a 95 F-150, the air bag light is flashing code 52. Any ideas why.
Old Sep 24, 2004 | 04:24 PM
HomerWinzlow's Avatar
HomerWinzlow
Charging system problems? Have you recently had a battery replaced? Be sure to check all your fuses.
Old Sep 24, 2004 | 07:56 PM
n578md's Avatar
n578md
Here's a listing of a few airbag codes:
12 Low Battery Voltage
13 Air Bag Circuit or Crash Sensor Circuit - Shorted to Ground
21 Safing Sensor - Not Mounted on Vehicle Properly
22 Safing Sensor Output Circuit - Shorted to Battery Voltage
23 Safing Sensor Input Feed/Return Circuit Open
24 Open in Circuit 944B or Low Resistance in Crash Sensor(s)
25 Passenger de-activation switch error.
32 Driver Side Air Bag/Safing Sensor Circuit - High Resistance or Open
33 Pin 7 Not Grounded at Diagnostic Monitor
34 Driver Side Air Bag/Safing Sensor Circuit - Low Resistance or Shorted
35 Low Resistance Across Pins 8 and 9 at Diagnostic Monitor
41 Crash Sensor Circuit - High Resistance or Open
44 RH Crash Sensor - Not Mounted to Vehicle Properly
45 Center Radiator Crash Sensor - Not Mounted to Vehicle Properly
46 LH Crash Sensor - Not Mounted to Vehicle Properly
51 Diagnostic Monitor Internal Thermal Fuse - Blown and Short to Ground No Longer Exists
52 Backup Power Supply - Voltage Boost Fault
53 Internal Diagnostic Monitor Fault
Old Sep 24, 2004 | 09:32 PM
albertafarmer
I replaced the battery about a year ago. The light was flashing before that, and still is. I've replaced various fuses since then.
Old Sep 28, 2004 | 08:19 PM
95f150's Avatar
95f150
Hello,
I got code 12 for my airbag (low battery voltage). I also pulled the codes off my ecm and i got (low voltage to tps), code 121, and 122.
I bought a new tps from ford and was wondering if i even needed it. My truck jerks at start like its not getting and gas, and sometimes it dies right down on highway speeds like i let off the gas. Could all this be that i need a new alternator or battery? I would rather much return the tps to ford if i dont need it, thanks
Old Sep 28, 2004 | 09:36 PM
Franklin2's Avatar
Franklin2
You can check the throttle position sensor by unplugging it, and hooking an ohmmeter up to the leads. Set the r scale to one which gives the most movement of the meter needle. When you push the throttle, the needle on the meter should swing smoothly. The tps is a potientiometer (variable resistor), much like the volume control on older radios. They can wear out.
elee3
Jul 31, 2009 11:06 AM
whruppe
Aerostar
Jan 16, 2008 09:05 PM
underDAWG
22
Jun 24, 2006 10:46 PM
fordtrucksforever
1978 - 1996 Big Bronco
30
Mar 14, 2006 07:26 PM
Fullcontact
1983 - 2012 Ranger & B-Series
Mar 8, 2006 06:58 PM
