1978 - 1996 Big Bronco
Electronic Shift Module
Old Sep 13, 2004 | 03:05 PM
philmo418's Avatar
philmo418
Unhappy Electronic Shift Module
After much investgation I beleive that the Shift Module has gone bad in my push button Four Wheel Drive. I have called just about every source I can think of and cannot find this part anywhere. A quick check with the dealer left me breathless, with a whopping $498.00 price tag. Can anyone suggest where I can find on used ?
Thanks!
Philmo.
Old Sep 13, 2004 | 08:25 PM
Trublufords's Avatar
Trublufords
www. car-part.com We see more problems with the shift motor bolted to transfer case- have someone under truck tapping on motor with hammer(key on) while someone is pushing 4x4 button- sometimes have to unbolt motor and tap on. GOOD LUCK!!!!!
Old Sep 14, 2004 | 12:03 PM
ojosdestranger's Avatar
ojosdestranger
I have one if you pick it up...
It is in South Texas
I am parting a 1995.
Old Sep 14, 2004 | 01:53 PM
philmo418's Avatar
philmo418
Thanks for the replies.
Ojodestranger, before your offer I found one for $35.00 on-line thanks to Trublufords suggestion. It would have worked out because I live in South Texas also. I did have the motor off and gave it a few good raps but still no go. There is no clicking noise and I metered the lead and it is getting both power and instructions from both the Four Wheel High and Low switches. I am confident that it is the module.
Philmo.
Old Sep 14, 2004 | 03:01 PM
ojosdestranger
Where in S. TX.
Mine is in Harlingen.
If you know anybody needing any parts for a 1995 Bronco, let me know. I'd like to help out the Bronco owners who are in need...
Stranger
Old Sep 16, 2004 | 09:20 PM
philmo418's Avatar
philmo418
New Braunfels
Stranger,
Sorry I took so long, I was on the road and sometimes I don't get to check my messages. I will keep my eye out for any one needing '95 parts.
Phil.
Old Sep 18, 2004 | 07:35 PM
Gooch's Avatar
Gooch
Did you take the cover off the motor cover. There is a plastic stop inside that breaks from temp changes,and it makes the plate inside out of time(for lake of a better term).You can repair it with a piece of 5/16 vacuum hose.You nwill need a tamper proof torx drive to remove the cover.
I saw this repair done on another web site when my Sons' truck did the same thing.
I can't think of site off hand ,but this might get you started.
Gooch
Old Sep 18, 2004 | 07:51 PM
Gooch's Avatar
Gooch
Just saw my son he reminded me of the site
try www.glue.umd.edu/~singletn/exp.html
I know this says it's for an Explorer but the process worked on my sons 94 F150. Just scroll down to where transfercase what to check first.
Hope this helps
Gooch
jdcii
Feb 5, 2010 07:11 AM
RedNBlack452
1983 - 2012 Ranger & B-Series
Jan 9, 2010 05:22 PM
2006musicman
Jan 15, 2009 08:00 PM
edy2112
Dec 29, 2004 02:51 PM
jan
Bronco II
Nov 25, 2002 07:35 PM
