EGR Disconnect Instructions
Dave..
My mods" bully dog programmer, 4' turbo back pipe, aftermarket intake...
i did notice better respons ,better engine start, i think i got like .9 % millage increase because on highway i usually got 13.6 mpg, today i got 13.9 driving between 65-75mph
OH yah turbo is much quiter than what it was with erg on and with a throttle plate... did like the sound of the turbo wistle with EGR and throttle plate installed... with out it truck has more deep sound , something like chevy truck with some wistle in between
This is the best thread I have seen regarding the problems with the EGR. I have 54,000 miles on my 2004 Ford 6.0 and have now gone through three EGR's and one turbo. I have the extended warrenty so has not cost me much (YET!!!!!!!!!!!!!). The prob has ruined one vacation while towing my trailer and my wife will no longer go due to the anxiety involved. My first EGR went out at about 15,000, the second at about 32,000 and the third along with the turbo at 52,000. I have taken the advise of the tread owner and unplugged the EGR connector wire today. I just took the truck for a 25 mile spin and noticed nothing different and no dash lights or check engine lights came on.
I'm in this for the long haul as from what I understand, all the exhaust crap should no longer be recycling through the intake. Is my assumption correct? I'm still a bit confused concerning removing the egr throttle valve as recommended. I have choosen not to do this since this this would be obvious tampering. The egr wire can just fall off!! I purchased the 2004 in November of 2003 so I'm not positive if I even have the egr throttle on mine. Am I ok leaving the throttle in and just disconnecting the wire?
Thanks a bunch!
You stated on top something about '04 builds, do you mean build date of the motor/truck, or model year. Curious as to if I need to do the plate mod as well.
Truck is a 2005
Truck was put into service 12/20/2004
What do you think, do I need to take a peek.
Thanks,
Chris
2005 Crew Cab Lariat 156" FX 4
4" Turbo Back
EGR Bypassed
BFG AT TK/KO
UWS Diamand Plate Box
My only question, is will my 05 Excursion pass NYS emissions with the EGR system disabled using a SCT tuner and removed EGR cooler. I assume NOx readings will be higher, but will it pass? I do have the cat still installed.
Thanks,
- Chris
if you have no CEL, and no missing cat, you should be golden. NY may be stricter, or may be less strict, all depends, but last time i smogged mine, the dude didn't even bother to check for a cat and wrote N/A on my paper just cause it was a diesel haha...
03 and older not required in nevada, but my 04 technically should have a cat for smog reasons ( which fell off sometime last year and i can't remember where)
The exhaust up-pipe (or y-pipe) has to be removed in order to eliminate the "scoop" inside. This scoop highly restricts the exhaust gasses to the point that you may even see soot trying to escape where the exhaust manifold meets the head! This evidence of soot will show you just how restrictive this egr up pipe is, however the drivers side manifold does not have this scoop and does not exhibit soot at that union.
This is an easy one man procedure that most anyone can do with basic mechanics tools.
Enjoy!
The first step in this modification is to remove the downpipe from your turbo.
This is a great time to upgrade to 4" aftermarket pipes! In these pictures I've already in place a Stainless Steel Magnaflow exhaust system.
Using a zip tie at the transmission will hold the end of your wrench in place. This is looking up from the drivers side.
Using a nylon zip tie will hold the socket firmly in place.
Using an extension from the passenger side remove the nut. I used penetrating oil on each bolt thread.
Take a magnet and remove the bolt. Notice the aftermarket 4" downpipe floating up in there.
A good telescopic magnet is an invaluable tool for those hard to reach places.
These two bolts are next. The upper bolt on the up-pipe and the stainless collar clamp on the egr cooler. They might look easy to get to but are way back in there near the firewall.
Using the same trick at the begining, zip tie your wrench end while using a combination on the nut.
A 3/8 air ratchet is the perfect tool for removing the egr cooler clamp at the up-pipe
Slide the egr clamp over the cooler and away from the up pipe. At the different colored union you can see where the up pipe and egr cooler meet.
Remove the lower bolts from the up pipe. Once all the bolts are removed, slide the now free pipe away from the exhaust pipe, This will give you room enough to fully remove the exhaust downpipe with ease.
Now that the 4" exhaust downpipe is removed, you can easily remove the egr y-pipe.
This up-pipe needed to be removed in order to modify it or replace it with one already modified. If you choose to replace it, Have one ready and on hand. You will need this for a refunded core charge.
The sheer size of the Magnaflow 4" downpipe puts this factory exhaust y-pipe in perspective.
The y-pipe is 2"
Here's the "scoop" that needs to be removed
The bright crescent area is the only flow area for the exhaust gasses, Now you get an idea why EGT's boils coolant so easily in the cooler, the exhaust is heavily Restricted. Just turning off the egr valve is not enough. This "scoop" has to go.
The next step is to decide how you want to fix the scoop, some have just cut it out with a sawsall from the side inlet port and then weld a plug in this Y part of the pipe feeding the cooler, others have removed the scoop, cut the Y part out of the pipe and welded a plate over the opening, while others have opted to buy an aftermarket pipe and replace it that way. I hope these pictures have been helpful to you and your 6.0.
Thanks for all the support here on FTE.
Last edited by Benchwrench; Sep 28, 2008 at 02:05 PM. Reason: pictures didn't load
Chris
Enjoy!
Way to do a write-up! Very good photos and instructions. It makes me really glad that I have an '04 and don't have to do this! I just don't have it in me lately to go the distance on some of the work. I may have gotten old when I wasn't looking.
__________________
I think the 03 pipe is a different size. I bought a stock pipe did the mods - removed the scoop it cost $85. I have the stock pipe - in-case I want to put it back to stock.
