Aerostar Ford Aerostar
Bouncing amp meter
Old Aug 18, 2001 | 05:02 PM
mr_s_edwards's Avatar
mr_s_edwards
Bouncing amp meter
I have a 92 aerostar with the 3L and ac. I find that when it sits there running the amp meter will bounce and the headlights flicker same with dash lights etc. I was told that it was the belt cause it was streched so I replaced it and still have the same problem. Ant suggestions? As soon as you touch the gas the amp meter stops bouncing.
It sure has me fooled,
Sean
Old Aug 20, 2001 | 09:07 AM
Mikeman's Avatar
Mikeman
Bouncing amp meter
First things first, I would check to make sure that the grounds are good. But, it sure sounds like the problem is the voltage regulator. I had the same thing happen on my '91 Escort and it's currently happening on my '91 Ranger. In the case of the Escort, I replaced the regulator because I happened to have a spare one laying around (doesn't everybody?) and it solved the problem. On my Ranger, I figured I would wait until the problem got worse since it only happens when things are just right at idle. I would try to troubleshoot this rather than just throw money at new parts. And if you do change the regulator, be careful that you don't lose anything in the process. I remember almost losing a spring because I didn't know it was there and I tried to do the job with the alternator still on the car. Fortunately, I found the spring, but next time I would just pull the alternator.
Old Aug 20, 2001 | 02:13 PM
Mikeman's Avatar
Mikeman
Bouncing amp meter
cornking
Jan 26, 2011 07:31 PM
powersfab
May 25, 2009 12:33 PM
Ford_250
Electrical Systems/Wiring
Apr 13, 2007 09:25 PM
sean23johnson
44
Jan 9, 2007 10:54 PM
mr_s_edwards
Aerostar
May 20, 2001 06:35 PM
