voltmeter or amp meter?
Old Apr 12, 2007 | 04:44 PM
Ford_250's Avatar
Ford_250
I am adding a set of aftermarket gauges, it is better to have a voltmeter or amp meter, and where should i set it up on?
Old Apr 12, 2007 | 05:25 PM
merlynr's Avatar
merlynr
Voltmeter and anywhere you have voltage with the key on. If new install, the instructions should be of some benefit.
Old Apr 12, 2007 | 08:49 PM
Franklin2's Avatar
Franklin2
I agree, a voltmeter will tell you as much info as an ammeter, and is easier and safer to hook up.
Old Apr 12, 2007 | 09:49 PM
SPL Tech's Avatar
SPL Tech
Voltmeter. Ammeters are obsolete when being used in the application you are suggesting.
Old Apr 12, 2007 | 11:03 PM
Torque1st's Avatar
Torque1st
Posting Legend
Voltmeter again!
Old Apr 13, 2007 | 07:11 AM
Ford_250's Avatar
Ford_250
thanks ya'll, i can't wait to get my dash done and get some pics up
Old Apr 13, 2007 | 08:04 AM
projectSHO89's Avatar
projectSHO89
FWIW, all voltmeters are ammeters anyway.....Just a matter of the display and the shunt ciruitry.
Steve
Old Apr 13, 2007 | 12:45 PM
Franklin2's Avatar
Franklin2
Steve
If I am thinking what you are thinking, the above is backwards. All ammeters are really voltmeters as far as moving the needle of the gauge.
Old Apr 13, 2007 | 01:44 PM
MisterCMK's Avatar
MisterCMK
Voltmeter. When you are installing it, make sure you have a good connection to get the most accurate results
Old Apr 13, 2007 | 03:27 PM
aurgathor's Avatar
aurgathor
That isn't necessarily correct. First, there are ammeters without any shunt circitry. Second, digital multimeters are almost always volt meters, while analog meters are usually ammeters.
Old Apr 13, 2007 | 04:18 PM
Franklin2's Avatar
Franklin2
The only ammeter I can think of, that is not a voltmeter of some type, is the old ammeters with the loop in the back, were you run the current carrying wire through the loop, and the ammeter picks up the field around the wire caused by the current flow. This possibly too could be considered some type of voltmeter, but that would be getting way over my head.
Old Apr 13, 2007 | 07:43 PM
projectSHO89
Nope, my original statement is correct. All mechanical meter movements require a certain amount of current flow through the movement in order to deflect the movement. Typically, these values are a up to a few mA of current although most are in the uA range for full-scale deflection.
Been doing electronics for 30 years, started out with test equipment....testing, repair, calibration, etc.
Steve
Old Apr 13, 2007 | 09:25 PM
merlynr's Avatar
merlynr
The "old" ampmeter Franklin described is a Tong meter or sometimes called an amprobe. The are very useful and can be bought "new" as I purchased one a couple of years ago. they rely upon magnet field around a wire with current running thru it for measurement.
Millenium Edition
Apr 11, 2012 01:47 PM
davewave649
May 27, 2011 11:22 PM
TNT in Round Rock
Jun 29, 2006 11:12 PM
Saxon
Apr 26, 2005 08:58 PM
mustang
Sep 29, 1999 02:28 PM
