Stop the vibrations
Old Sep 12, 2004 | 08:00 AM
evan250's Avatar
evan250
Red face Stop the vibrations
My E250 6 cylinder automatic starts to vibrate at about 55 mph. It seams like the body rather than the engine is vibrating. Right now the inside of the van is empty, I am converting it to a camper. Any Ideas on the vibrations?
Old Sep 12, 2004 | 09:03 AM
Mustang 5.0's Avatar
Mustang 5.0
If good vibrations, I'd think you have the Beach Boys turned up too loud on the stereo...... (am I showing my age?)
Old Sep 12, 2004 | 05:02 PM
evan250's Avatar
evan250
bad vibrations
i grew up on the beach boys and grand funk railroad. While taht is all good and well I still want some ideas of what could cause the vibrations.
Old Sep 12, 2004 | 05:19 PM
Phantom's Avatar
Phantom
Have the wheels / tires balanced first. Then go to the drive shaft.
Old Sep 13, 2004 | 07:38 PM
evan250's Avatar
evan250
Red face still vibrates
the wheels / tires are new. no shimmy on front end when I drive. I thought that the driveshaft would make is vibrate even at slow speeds. I will check it anyway. Thanks for the info.
Old Sep 14, 2004 | 12:15 AM
Leo_T's Avatar
Leo_T
I had a diff act like that. Vibration came in hard at 60, and smoothed out at 70. When in doubt replace the cheapest, and easiest part. Keep the diff in mind, just in case the easy fixes don't work. I had my driveshaft balanced, and checked for run out..new universals put on. That helped alot. Eventually put in a used diff with low miles, that finally fixed it.
Vibration problems will drive you to drink.
Old Sep 14, 2004 | 12:22 AM
pfogle's Avatar
pfogle
Even though the tires are new, they can still be out of balance. They only balance them at ~25mph.. This can cause problems above about 50mph... It's a complicated process, but it works. If the shops balancer is out of spec it will not balance well.
Old Sep 14, 2004 | 09:23 PM
cocot's Avatar
cocot
Definately check the U-Joints. 50 to 60 mph is where they usually vibrate.
Old Sep 14, 2004 | 10:36 PM
Little Bro's Avatar
Little Bro
Even new tires can have separations. My daughter's car had symptoms like you describe. I told her to look carefully at all the tires for bumps on the sidewalls. She didn't see any, so she took it to Les Schwab, where they did find a separation which wasn't visible but which was causing the vibration. If the problem is in a rear tire, you might not feel much in the steering wheel.
Look around the edges of your wheels to see if there's any evidence a balancing weight might have been thrown off recently.
Sinntax
Jul 13, 2017 07:16 PM
roboduck75
Mar 22, 2017 10:35 AM
-dave-
Dec 3, 2015 01:28 PM
Ghoti
Dec 18, 2006 08:03 AM
Silver4bye
Jul 5, 2005 01:20 PM
