valve rotators,
Old Sep 11, 2004 | 05:59 PM
dennyjr47's Avatar
dennyjr47
valve rotators,
77 f150 351m, can you put normal retainers in place of exhaust rotators, bought edelbrock spring kit , don't know if mine are rotators or not,intake retainers are solid 1 pc. the exhaust are 2 pc not solid,is that a rotator?? the new kit is all retainers(solid),the springs are almost equal,not shorter for rotators.
Old Sep 11, 2004 | 08:24 PM
dennyjr47's Avatar
dennyjr47
my basic question is , can i get away with taking the rotators off and putting the same size springs & retainers on all around, edelbrock spring kit edl-5872 non-rotator,is the kit i have.
Old Sep 11, 2004 | 10:19 PM
mark a.'s Avatar
mark a.
Yes, you can.
Old Sep 11, 2004 | 10:59 PM
dennyjr47's Avatar
dennyjr47
would i need to change the exhaust valves for stem height
Old Sep 11, 2004 | 11:09 PM
Rancheroracer's Avatar
Rancheroracer
Your new springs should have come with a spring height #. Also, aren't your valves multi-groove? If so, valves will still rotate.
Old Sep 11, 2004 | 11:27 PM
dennyjr47's Avatar
dennyjr47
installed height is 1.82 in. & 1.68 ex .with rotators, stock, new kit is 1.82 installed height in. & ex. with retainers, no exhaust rotators,seems like it would still bind on the ex. side
Old Sep 12, 2004 | 01:33 AM
Rancheroracer
If you have multi-groove valve locks, they don't grip the valve stem, you'll notice when you install them there is no gap at the lock sides, which leaves the valve stem free to rotate in the locks. Single groove locks & valves grip the valve stem and have a gap at the sides.
Old Sep 13, 2004 | 12:30 PM
dennyjr47's Avatar
dennyjr47
thanx ,gonna attempt next weekend,hope they are multi-groove valves
palmrose2
51
Jul 18, 2016 08:20 AM
trozei
Jun 16, 2016 02:57 AM
jereli
Mar 23, 2016 07:21 PM
Zack88
13
Jan 22, 2016 05:28 PM
BTFordGuy302
Oct 28, 2015 08:41 PM
