which 2bbl??
Old Sep 15, 2004 | 08:52 AM
Oscar Meier's Avatar
Oscar Meier
You may also want to look at a web site www.gofastforless.com There are instructions for converting to a Ford DSII dizzy and a GM HEI Module. I did this conversion to my '86 300 and I could not be happier. You don't have to mess with a DSII harness and no ballast resistor to install. It's a good deal and not any more difficult than a DSII conversion.
Old Sep 15, 2004 | 02:51 PM
84-250's Avatar
84-250
i went to a junkyard and found the harness and dizzy. then went to parts store and got a module. if you use the tfi coil you dont have to use a ballast resistor and its more powerful too.
Old Sep 15, 2004 | 03:43 PM
Oscar Meier
You're lucky - In Indiana they are crushing everything up to '95's and finding DSII parts in a yard is next to impossible. Any more, we are forced to buy a Junker/parts truck to get any used parts.
We have a very few yards that you can get older parts; but, the trucks are pretty well picked over now. Most left are just stripped frames and rusty cabs.
Old Sep 15, 2004 | 07:53 PM
84-250's Avatar
84-250
over here in ohio we have some yards that stock late 70's trucks
Old Sep 16, 2004 | 02:53 AM
Katmandu's Avatar
Katmandu
Question
What year/models are the Duraspark ignition used on ??
Old Sep 16, 2004 | 07:15 AM
84-250's Avatar
84-250
ds2 was used on my trucks, 70's to mid 80's. you can get the harness and module from any truck that has ds2 but you need to find a truck with your engine to get the dizzy.
Old Sep 16, 2004 | 09:16 AM
pchristman's Avatar
pchristman
Before I embark on my scrounge, how much of what harness do I get? Just the part from the module to the distributor? Or, all the way back to the ignition switch?
Can I keep my "E" core coil from the TFI system?
Old Sep 16, 2004 | 09:53 AM
Oscar Meier
The part for the module to the dizzy & yes it's better to keep TFI coil. Good luck with your hunt.
Old Sep 16, 2004 | 12:03 PM
pchristman's Avatar
pchristman
Thanks. That's what Ive been looking for. I'm off to a rendezvous in the morning, but it's out to U-Wrench-It on Monday.
Old Sep 16, 2004 | 12:33 PM
Katmandu's Avatar
Katmandu
Question
Old Sep 16, 2004 | 10:55 PM
MontanaFord's Avatar
MontanaFord
would napa possibly have the module, dizzy and harness???
MontanaFord
Old Sep 17, 2004 | 09:08 AM
82F1507.5's Avatar
82F1507.5
Just a note on connections
When making up the harness connection to the distributor (dizzy) be sure to include quick disconnects on the wires aternating from male to female so they can not be hooked up backward at a later date. You will be glad you did if you have to pull the distributor in the future.
Old Sep 17, 2004 | 06:45 PM
  #28
PaulzF150's Avatar
PaulzF150
The Duraspark II ignition was used from 1976-1983.
MontanaFord
Jan 10, 2005 12:13 PM
MontanaFord
Nov 9, 2004 09:02 PM
MontanaFord
18
Sep 13, 2004 12:26 AM
MontanaFord
18
May 1, 2004 11:12 AM
