Sponsored by: Auxito
brake question
Old Sep 9, 2004 | 09:05 AM
jason86's Avatar
jason86
brake question
I just replaced the front brake rotors and pads on my '97 F-150 4x4 and I am still feeling a pulsing in the brake pedal. Has anyone experienced this?
Old Sep 9, 2004 | 09:52 AM
frazier23727's Avatar
frazier23727
my father in law had a 97 F150 that had pulsing brakes. He had air in the brake line. have you tryed bleeding your brakes.
Old Sep 9, 2004 | 10:08 AM
jason86's Avatar
jason86
no, But I will try that, thanks
Old Sep 9, 2004 | 09:05 PM
Racerguy's Avatar
Racerguy
Are you sure the pulsation is from the front?
Warped rear drums can cause it too.
Old Sep 10, 2004 | 08:19 PM
y2klarry's Avatar
y2klarry
I agree with the warped drums. You can test them by slowly stopping only using your e brake. Do this in a quiet area of town and you only need to travel at 5 mph. If the drums are warped you will probably feel the whole truck lurching/surging.
Old Sep 10, 2004 | 09:04 PM
03f150man's Avatar
03f150man
1997 f150 173000 miles.
recently the truck has had a clunking noise when applying the brakes, so today i gently but steadily applied emergency brake while driving around 40 mph. while pushing on the ebrake and about a 1/4 of the way down, i hear a loud "clunk" which sounded exactly like the clunks i heard before. I tried it 3 times and each time i heard the clunk. the clunk seems to come from the rear of the truck.
This truck has front disc and rear drum brakes. No ABS light on.
I replaced rear shoes at around 100k but otherwise the rear brakes are stock. I've also recently experienced some mild pulsation when braking but my front rotors are i think in good shape so from Racerguy's comments the rear drums may need turning. Easy to think the problem is just rear drums but before i take them off would like to hear your ideas i.e. is maybe the
e cable at fault or ?
thanks for any suggestion.
Old Sep 27, 2004 | 09:01 AM
jason86's Avatar
jason86
Question
Ok, I replaced the front brakes and rotors, bled the front brakes, replaced the rear drums and still have the pulsation. WTF?
Any ideas?
Old Sep 27, 2004 | 06:21 PM
Realgun's Avatar
Realgun
Wow same thing
Ok did you turn the drums?
Old Sep 27, 2004 | 09:42 PM
03f150man's Avatar
03f150man
as racerguy said the rear drums can cause the pulsation
Old Sep 29, 2004 | 08:48 AM
jason86's Avatar
jason86
Any ideas?
Yes, I Replaced the rear drums. Apperantly a waste of $75.
Bad 674x4
Apr 29, 2013 09:57 AM
Larzon
Nov 18, 2012 06:56 PM
4BTF250
May 18, 2008 06:59 AM
JRFX4
2004 - 2008 F150
Dec 18, 2004 09:52 AM
nikwave
Feb 27, 2004 05:32 PM
