Sponsored by: Auxito
Check Engine P1131
Old Sep 21, 2004 | 12:25 PM
Dong4242's Avatar
Dong4242
Red face Check Engine P1131
Hi all, I've 97 F150 4.2 V6 Supercab, I'm not sure who's fault was it, starting from L.A I put a Gumout Fuel Injector Cleaner and a Full of Super unleaded. after i drove over 150 miles coming back home, "Check Engine light on" Truck was fine no problem at all, So the next day i when to Autozone to rent the Readers code. Plug Reader and i got "P1131 Manfacturer Control Fuel Air Metering" and I don't have any clue where start, Any help will be much appreciated.
Thanks
Roland
Old Sep 22, 2004 | 08:41 AM
Racerguy's Avatar
Racerguy
Hi Roland and welcome to the forum
A P1131 means that the truck's computer (PCM) thinks the engine is running too lean and has richened up the air/fuel mixture as much as it can to try to compensate for it.
Checking for vacuum leaks would be a good place to start. How old is your fuel filter? Ever cleaned the MAF sensor? How old are your spark plugs?
Old Sep 22, 2004 | 05:10 PM
Dong4242's Avatar
Dong4242
Hi, Thank for replying to my post! Well it's been over 50,000 miles since dealer replaced my Fuel Filter, Maf sensor and spark plugs still original never been touch. I guess these will be week-end project for me, Ok one more thing need a book to start, I'm open for any suggestions and guidance..thank you again.
Old Sep 22, 2004 | 05:23 PM
Racerguy's Avatar
Racerguy
A shop manual would be a good idea but if you look in the Frequently Asked Questions at the top of this forum and do some snooping around in here you'll probably find all the info you need to do the work.
Good luck, have fun and let us know how it goes
Old Sep 29, 2004 | 09:50 AM
Dong4242's Avatar
Dong4242
Thumbs up
Hi, My truck is back on the road again!!!Thank you Racerguy for the info. Replaced Air filter, Cleaned MAF sensor and disconnected battery fo few minutes. Started the truck the next day and the check engine light was gone..Thanks again Racerguy and Ford truck enthusiasts..
donbelcher27
Modular V10 (6.8l)
Feb 17, 2012 08:45 PM
koby_777
1997 - 2003 F150
15
Oct 2, 2006 03:47 PM
stephen410
1997 - 2003 F150
Sep 20, 2006 11:09 PM
hood
General Automotive Discussion
Oct 4, 2005 07:13 AM
jabo99
Modular V10 (6.8l)
Dec 29, 2004 11:41 AM
