S code spring?
Old Sep 19, 2013 | 07:54 PM
RKraft's Avatar
RKraft
S code spring?
I am wondering if any has used or nows anything about S code springs out of 2004 F250. I found a set not sure of miles but guy ran the vin at dealer & they said S codes with over loads. Any information or advice would be grateful.
Thank you,
Randy
Old Sep 19, 2013 | 08:08 PM
WE3ZS's Avatar
WE3ZS
Thank you,
Randy
S codes should be front springs from a very light SuperDuty. According to my notes from this site the S code is rated at 4000lbs vs the stock V-10 Ex C codes at 3680lbs and the PSD EX D codes at 4080lbs. The popular V codes are rated at 5200lbs. I don't know what they are describing as having overloads, fronts didn't come with any overload setups.
Old Sep 19, 2013 | 10:34 PM
RKraft's Avatar
RKraft
OK, these are rear springs with the aux leafs. I might pass on them then, since they are out of truck and the truck is not around. I found a salvage yard a few miles from me that has both B & C codes for about $200 for the set. Would like new but not in budget right now. I really want to do this swap before snow flies. Springs are sagging more and ride quality seems to getting worse also. Here is a picture of the springs
Randy
Old Oct 25, 2013 | 12:54 AM
PoPs 03DEX's Avatar
PoPs 03DEX
Those look like the B with the top overload.
Old Oct 25, 2013 | 07:44 AM
wpnaes's Avatar
wpnaes
If you decide to use 'em on an Ex, remove the top overload.
IMO, as is, price should be closer to 100.
BeesX
Jun 12, 2025 02:27 PM
pkthomas
Nov 12, 2016 03:41 PM
wildstang
Jun 16, 2012 03:39 PM
SilverBullet131313
May 5, 2010 02:27 PM
broncorif
Mar 23, 2010 06:20 PM
