Modular V10 (6.8l)
reflashing computer
Old Sep 5, 2004 | 05:58 PM
EPDP99's Avatar
EPDP99
reflashing computer
I have a 99 f-250 v10 and sometimes when it shifts it has a slight ping. I have been told that it is the knock sensor and my computer had to be reflashed. How do I do this. I have taken it to 2 local FORD dealerships who say they cant look up the knock sensor information and cant "reflash" the computer. Please help.
Old Oct 28, 2004 | 05:24 PM
F-Deuce50's Avatar
F-Deuce50
Boy that sux.....F)@)*$)*$# FORD
Old Oct 28, 2004 | 07:27 PM
bruuuuce's Avatar
bruuuuce
I would say it is more they don't want too than they can't. Find a better dealer service department.
Old Oct 28, 2004 | 07:51 PM
super 6.8's Avatar
super 6.8
A slight ping is no big deal. Use higher octane and it will go away. I find it hard to believe you would have to reflash your computer unless there is a recall or TSB recommending to do it.
Old Oct 28, 2004 | 09:52 PM
DJR 17's Avatar
DJR 17
Welcome to my world. 1st it was mid grade, that worked for a few months. Now I'm stuck running super. New plugs didn't help either. Forget about resetting the computer, that was also hopeless.
Old Oct 28, 2004 | 11:43 PM
Racerguy's Avatar
Racerguy
Have you tried cleaning the MAF sensor?
If it's dirty it can cause a ping.
Old Oct 29, 2004 | 11:51 AM
Fredvon4's Avatar
Fredvon4
From 1999 to 2004 the OBD II program within the Power Control Module (PCM) that controls the engine and auto trans has gone through several upgrades in software and firm ware. There are over 30 PCM codes and many can be reflashed to correct various problems. However many of the "codes" are not compatable with different combinations of eguipment or vehicle use.
As an example in 2001 Ford had a code for Sea Level and High Altitude, and a different code for most other states Sea Level. There was also a different "code" for auto trany vs. manual Trans. Sometimes to "correct" a customer complaint about "flutter" a Ford tech would reflash in a new code and the flutter would disapear or be at a different RPM.
Unfortunatly the owner also experianced very reduced HP and Torque from the new code.In the early years many of us on this site and the "diesel" site tried to compile a list of all the different codes and what characteristics of the trucks they were in. We wanted to make some sense of the difference codes. We never got a complete picture as Ford was changing the codes faster than we could keep up with the new truck owners loggin in for info.
Many of the "chip" companies required that you provide the factory "code" so they could custom program the chip to increase or decrease the ramp rates of the injectors and ignition.
Starting in 2005 Ford changed to a new inter communication method with the peripherials and the computer (PCM) called Controller Area Network (CAN)
Go to
https://www.fleet.ford.com/truckbbas/non-html/2005/whatsnew2005.pdf
to learn more about 2005
Old Oct 29, 2004 | 07:09 PM
MYFRST10's Avatar
MYFRST10
Hey epdp, Just thought I`d share this with ya , hope it helps.
I was having the same trouble you were with that tapin at the top
of each shift. It drove me crazy for months. Everyone who looked at it
had a different thought as to what it was . Lifters ,rattles, piston slap
nothing just drive it , you name it . Anyway I took it to a small town
shop afew miles from me , and he thought it sounded like rod bearing .
So we pulled one plug wire at a time and then put them back lookin for a change in the sound .And sure enough when we got to # 10 the noise
stoped .put the wire back on ,noise came back.So #10 was the trouble.
So we drop the pan an sure enough#10 bearing was shot.The crank looked great so I chose to sneak just #10 in and hope for the best, so far so good.
no more slapin its only been about 4 thousand miles so we`ll see what happens.
$485 and one day in the shop I thought it was worth a shot. still sounds great.
Anyway I hope this helps ya, good luck
brandon.edwards
Jan 22, 2013 03:45 PM
Why Not
Kansas Chapter
Jun 5, 2008 05:45 PM
bigpowerstroke
Nov 6, 2007 07:37 PM
mike_65
1997 - 2003 F150
Jun 18, 2004 02:24 PM
