1978 - 1996 Big Bronco
?Another Clock Spring Problem?
Old Sep 4, 2004 | 11:34 AM
Columbus's Avatar
Columbus
From the reading I've done on the forum it seems like the clock spring causes a lot of problems. Was wondering if it sounds like the suspect in this situation.
Airbag code 12 Low Battery
ABS Code 17 Lost voltage reference
ABS Code 63
This combination seems to point to a common fault. I thought it might be an old or bad battery but I have > 12 volts at the battery.
Do they sound connected? Is there some other testing I can do to narrow it down?
Old Sep 4, 2004 | 02:19 PM
screwy's Avatar
screwy
They sound connected but I cant find any connection between the two systems, other then the main power connections. Have you checked all fuses and the battery terminals?
It’s not the clock spring.
Rayrider911
Jun 16, 2014 08:59 AM
Redfridge
Feb 2, 2014 08:39 PM
rikfish
Aug 3, 2007 10:43 AM
411splicer
Aerostar
May 6, 2007 11:45 PM
Dunco
Aerostar
Jan 22, 2006 01:40 PM
