Spark Plugs
Old Aug 26, 2004 | 04:57 PM
AKranger's Avatar
AKranger
Spark Plugs
I am planning to change plugs in my 1999 3.0FFV Ranger with 60,000 miles.
The owners manual recommends AGSF12PP plugs, however Ford Dealers says that plug has a new number (AGSF22PP) but is the same plug. My manual states this plug is for the 4.0 engine.
Is Ford stating the facts that the plugs are the same? Any problem installing the AGSF22PP in my 3.0FFV?
Is 60K miles too soon to change plugs?
Old Aug 26, 2004 | 06:31 PM
Peter94's Avatar
Peter94
maybe the new plugs are to help fight pinging, the only different number is from 12 to 22, i believe thats the heat range of the plug.
Old Aug 26, 2004 | 06:41 PM
Rockledge's Avatar
Rockledge
I would recommend against the AGSF22PP plugs in your FFV 3.0L. Peter is on the right track with the heat range #s, however, the 22's are actually a hotter plug than the 12's, and that's not what you want in there:
https://www.ford-trucks.com/forums/s...d.php?t=240714
Old Aug 27, 2004 | 07:05 AM
RJC1's Avatar
RJC1
If you want to use aftermarket plugs
I own the exact same year and model but have 90k on it. I installed the Autolite DP (double platinum) based on many other posts that said they worked well in the 3.0 FFV. I have to admit they were right. I have noticed a much smoother idle and response. If you were thinking about an aftermarket plug I would highly recomend them . Good Luck
Old Aug 27, 2004 | 07:57 PM
AKranger's Avatar
AKranger
Hi RJC1, do you know the number of the Autolite DP plug you used?
Old Aug 27, 2004 | 08:55 PM
Big Jim M's Avatar
Big Jim M
Smile
Howdy Ak
My opinion is that the 60K is way to soon. I think you souuld pick a plug that is easy to get to and pull it to see what it looks like. I betcha that it is good to go. I keep the plugs twice that long before changing them and I always go back with the EXACT plug that the factory put in there. I don't think another company can get it as RIGHT as Ford can.
Big Jim
Old Aug 27, 2004 | 09:40 PM
southernfordman's Avatar
southernfordman
when i changed my plugs in my 2000 4.0l with 43,000 miles on it i still went with the autolites 764 from ford
Old Aug 28, 2004 | 09:56 PM
RJC1's Avatar
RJC1
App103
Autolite Ignition APP103
You can see more of a discription here
I think they go for around $4 per plug
RC
Old Aug 29, 2004 | 06:38 AM
Bob Ayers's Avatar
Bob Ayers
I tried the AGSF22PP plugs in my 1999 3.0L FFV, and they ran too hot. I found the AGSF12PP plugs, which cured the pinging, and roughness symptoms I had with the AGSF22PPs. Last November, I visited the Motorcraft booth at Sema, and they suggested a new "fine wire" platinum plug, P/N AGSF12FMF6. I have tried these plugs, and they run fine!! The only reason I can think Ford would discontinue the AGSF12PP, and to go to the AGSF22PP is to reduce inventory cost, so they only have to stock the "22", since it's used in the 4.0L also.....just my $0.02....
Old Aug 29, 2004 | 01:03 PM
CosmoKramer79's Avatar
CosmoKramer79
So how many miles should past before you recommend changing out the spark plugs? 30,000 miles?
Old Aug 29, 2004 | 02:49 PM
Big Jim M's Avatar
Big Jim M
Smile
Late model unleaded low compression engines in good condition? 90,000 miles up! Personally I run them till something shorts out! A wire or coil or something. Then I do a complete tune up. This has been over 100K in the past few years.
Big Jim
Old Aug 29, 2004 | 03:25 PM
Bob Ayers's Avatar
Bob Ayers
The recommended change interval from Ford is 100K miles.
Old Aug 29, 2004 | 04:47 PM
CosmoKramer79
Ahhh, k. Thanks! I might buy those Autolite DPs just for the heck of it since they're so cheap. I have an 01 3.0 Edge with a little over 37K miles on it! I have that pinging issue when I put in the 87 octane gas, but goes away when I put in the 93. So maybe the autolites might help!
HaroldCallahan
3.0L V6
21
May 25, 2022 04:24 PM
funtwohunt
Oct 3, 2012 02:06 AM
ptf18
Oct 30, 2011 08:42 AM
Bob Ayers
20
Jun 22, 2003 03:02 PM
fejetmech
1997 - 2003 F150
Apr 17, 2003 08:47 PM
