Aerostar Ford Aerostar
E4WD light blinks 9 times
Old Oct 15, 2004 | 05:18 AM
sarkis's Avatar
sarkis
clean the connections how? With permaseal contact cleaner spray?
Old Oct 15, 2004 | 05:20 AM
sarkis's Avatar
sarkis
How do I Search this forum? I cant find a link that works.. What i wish to do is to
close out some off my posts showing the problems were fixed and how..........
Old Oct 15, 2004 | 06:29 AM
M.Herrington's Avatar
M.Herrington
the search function disappeared the other day
Old Oct 15, 2004 | 08:26 AM
Aerostar1's Avatar
Aerostar1
Even without the electonic module connected, you still have AWD. Repeat: Even without the electonic module connected, you still have AWD. It is mechanically set to provide one third torque to the front and two thirds to the rear. The only time the electronic control is needed is when a wheel completlely loses traction. Then the transfercase locks briefly, sending torque to the opposite axle. If you get tired of chasing problems and spending money, just hook a momentary push button switch directly to the transfercase clutch. It takes 12 volts and about 6 amps. If you are stuck and spinning a tire, push the button for added traction.
Old Dec 16, 2004 | 01:01 PM
mrjbnak's Avatar
mrjbnak
Having read all of the above, I am wondering if these same sensors could be causing my electronic speedo to just quit. Fuse checked good. but nothing to the speedo section of dash. Left section tach still works with electronic gauges. I have a 1991 Aerostar XLT4wd.
dirtriderdan
Electrical Systems/Wiring
Jul 17, 2014 07:03 PM
gcextreme
1983 - 2012 Ranger & B-Series
Sep 18, 2010 01:03 PM
3rd97aero
Feb 18, 2006 05:49 PM
bbillman
May 1, 2003 12:52 AM
