1978 - 1996 Big Bronco
Help! Rear Window Question!
Old Nov 27, 2005 | 07:15 PM
Xxbronco90xX's Avatar
Xxbronco90xX
I have a 1990 Ford Bronco XLT 5.8 Liter, 4 x 4, and i have power windows on the rear that just stopped working. the window always went up and down as i pressed the window switch to move it, but i lowered the window all the way to the bottom and then it wouldnt go up anymore. it stopped working. any ideas whats wrong with it? how may i replace the window motor if needeD if the window is still stuck there? thanks
Old Nov 27, 2005 | 07:40 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Nov 27, 2005 | 11:13 PM
greystreak92's Avatar
greystreak92
Welcome to FTE and the Big Bronco Forum. There are many many threads on this topic. Check out the FAQ's at the top of the forum list here. There are a couple of good links for troubleshooting and repairing the rear window and more information has been posted about this problem than anything else. You might also try a search of this forum for more info.
Given it just suddenly quit, I'd make certain the driver's side latch is fully engaged before assuming there is something worse wrong with it. If the latch doesn't fully engage, the window will not move...its a fail-safe device so you can't inadvertantly close the window with the tailgate open.
Old Nov 28, 2005 | 08:44 AM
BillyBob69's Avatar
BillyBob69
What greystreak said. There is a safety switch inside the tailgate that senses if the tailgate is closed all the way by the position of the drivers side latch. This has been a common prob. I used to have to close my tailgate harder about once every 3 months to get the window to close. Try closing it harder or push in on the drivers side of the tailgate while using the key switch. If it works, then you prob is related to the safety switch. It could be you need a new bushing on the strike bolt, or the switch itself is going. Both are pretty cheap to replace.
Old Nov 28, 2005 | 06:58 PM
sailboat2323's Avatar
sailboat2323
Just bypass the switch altogether, easiest fix no more problem then.
Old Nov 28, 2005 | 09:31 PM
imlikeojnow's Avatar
imlikeojnow
deleted---didnt read billybobs post. nevermind
fastjza80racer
Apr 20, 2016 05:37 PM
bbygirl778
Oct 3, 2015 02:42 AM
joegeds
Mar 17, 2014 12:32 PM
fod
Jun 7, 2011 01:12 PM
uscrpick
Mar 11, 2007 09:08 PM
