1966 - 1977 Early Broncos
1969 Bronco - Steering problem
Old Aug 22, 2004 | 12:09 AM
kerdog99's Avatar
kerdog99
Has anyone had a problem with the steering wheel retaining nut backing out. The nut has back out enough two times to where you can't steer anymore. Has anybody ever seen a lock washer or something to keep this from backing out. Or you think something is stripped. Let me know your thoughts.
Thanks
Mark
Old Aug 22, 2004 | 07:57 AM
ken75ranger's Avatar
ken75ranger
Sounds like you have an aftermarket wheel. The factory one need a puller to come off the column even if the nut is off.
Old Aug 22, 2004 | 07:42 PM
Mike W's Avatar
Mike W
I agree. Even the aftermarket ones with the aluminum adapter need a puller to get off.
Old Aug 22, 2004 | 10:38 PM
68 351 bronc's Avatar
68 351 bronc
Just take a ball peen hammer and use the rounded end to rivit the locking end of the nut a bit before puting it back on the shaft over the steering wheel.
Old Oct 7, 2004 | 11:04 AM
rdhanks's Avatar
rdhanks
My bronco has a spring under the steering wheel to provide a positive force against the wheel similar to how a lock washer acts. Also consider a locking compound like Loctite.
Old Oct 7, 2004 | 01:12 PM
jlong1974's Avatar
jlong1974
What?
james
Liquid10Rider
Nov 16, 2010 08:46 PM
regidog
Feb 21, 2010 08:49 PM
bishopgeer
Sep 11, 2009 08:05 AM
plumnuts
Oct 11, 2005 05:51 AM
mathelm
1983 - 2012 Ranger & B-Series
Dec 9, 2002 04:58 PM
