Sponsored by: Real Truck
03 SD Steering loose
Old Oct 6, 2005 | 11:59 PM
plumnuts's Avatar
plumnuts
Truck wanders all over the road... 2 inches of play in the steering wheel...I did a search in this forum and not clear on the final word on loose steering with the 2003 SD diesels..6 liter. My Ford dealer and tire company say there is no adjustment of the steering box (I have ruled everything else out, new tires, alignment, loose parts)...
so, is there an adjustment or not??? Is the adjustment like the older Fords where you loosen the lock nut, turn the screw in a little, and tighten the nut back??
Old Oct 7, 2005 | 12:39 AM
KenB's Avatar
KenB
Suggest you take it to an alignment/front end shop. See if there's one in your area that specializes in trucks. Pay them for written diagnosis if need be, then take that to dealer.
Unless you're still under warranty, don't ask Ford dealer to find a problem or a tire company about a tire problem. If you must go to either, you'll probably have to get insistant.
Old Oct 8, 2005 | 12:54 AM
plumnuts's Avatar
plumnuts
yep still under warranty... been there done that, but maybe if I get something in writing maybe I can get FORD to fix it!!! Any ideas out there???
Old Oct 9, 2005 | 08:33 PM
plumnuts's Avatar
plumnuts
anyone else with ideas???
Old Oct 10, 2005 | 06:35 AM
slc10844's Avatar
slc10844
If there is 2"s of play in the steering wheel you need to find out where it is coming from. Is the play when the truck is at rest or when driving down the road? You want to eliminate everything else, including tire pressure, before attempting to adjust the steering box. Check the steering box and steering linkage by having someone rock the steering wheel back and forth with the engine running and wheels on the ground. Watch the steering shaft and the pitman arm to see if they move in unison. If the shaft moves and the arm doesn't, loosen the lock nut on top of the steering box, turn the adjusting screw about 1/8 turn, tighten the lock nut, and check again. You want to be careful not to over tighten. It can cause binding and gear damage. If it takes more than a half turn the gear box may be bad.
Since it is still under warranty, if you find anything loose take if back to the dealer and let them deal with it. Once you start changing things, like the adjustment on the steering box, they will blame to problem on what you did and deny any repairs.
Old Oct 10, 2005 | 02:02 PM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
Your doing the right thing by going to the dealer and asking... your asking here... but as advised in a post above... get a second opinion from another Ford dealer or alignment shop that works on trucks!!
This way you will know and be better prepared to "do battle". Over-inflating of these tires really causes my truck to "wander". My Excursion with stock tires and suspension says 50lbs in the front, but I run 57 - 60lbs. More than that and my tires do not wear properly and I have a lot more "wandering" as I drive at high speed.
Good luck and let us know what you find out.
Jeff
Old Oct 10, 2005 | 07:30 PM
plumnuts's Avatar
plumnuts
one more thing... the local Ford dealer said there is no adjustment on the 03 SD diesel... is this true or false??... I have looked (the area is tough to see because of the battery and box) and it appears there is a steering box but can't see if there is an adjustment screw...
Old Oct 11, 2005 | 05:51 AM
slc10844's Avatar
slc10844
Maybe you should look for a new dealer. I don't know what Ford policy is on gear box adjustment under warranty, but there is definitely an adjustment. To the best of my knowledge all steering gear, including rack and pinion, have a preload adjustment. Look at the power steering pump. Directly below and in front of the pump pulley is the gear box. On top of the housing is a silver colored plate with the adjusting screw and lock nut. I suggest you only let a trained professional make any adjustment to the steering gear. In order to properly adjust the mesh load requires special tools and procedures.
ManfredVonRichtofen
19
Oct 1, 2020 10:36 AM
insurr3ction
Dec 1, 2018 12:53 PM
99expyTN
6.4L Power Stroke Diesel
Oct 17, 2014 05:44 AM
Snuggyworm
Dec 16, 2012 09:14 AM
rosa70
Aug 10, 2005 12:49 PM
