Sponsored by: Auxito
Abs light abs question?
Old Oct 12, 2007 | 10:32 AM
Forced347sn95's Avatar
Forced347sn95
1997 F-150 Ok the bum I that traded me this truck must have burned the abs light and check engine light on purpose. Pulled cluster and replaced lights. Anyway, the abs light is on also with the brake light. Took it to my buddy at the Ford dealer to see what sensor might be bad and the scanner wont link up to the abs system. Go figure. I noticed there are no front abs sensors or wires. Aren't there supposed to be front abs on these trucks? Thought it might be possible he took it off. Would this just have rear abs off the rear end housing?
Old Oct 12, 2007 | 10:56 AM
projectSHO89's Avatar
projectSHO89
Advanced SEARCH > keywords "+RABS +light" (or+lite) > Username "projectsho89"
Been covered numerous times.
Steve
Old Oct 12, 2007 | 11:02 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
The light could be on just for the simple reason that your brake fluid is low.
Other than that...I would just unplug the light again :missingt RABS is a joke anyways...
Old Oct 12, 2007 | 11:09 AM
Forced347sn95
no brake fluid is fine. Still wondering if supposed to have front abs or not? I know it would be easy just to unplug both lights since the breaks work fine I just like to have things working right
Old Oct 12, 2007 | 11:19 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
No, it probably wasn't equipped with 4-wheel ABS. Not many of these trucks were.
Old Nov 14, 2008 | 11:26 AM
arjr111's Avatar
arjr111
Hopefully, it is just the diff. sensor which is a $20 buck 10 minute change, as opposed to the Rabs module which is a $500 plus change out.
Old Nov 14, 2008 | 11:44 AM
Lazy K's Avatar
Lazy K
The first thing to check is the wiring connector at the master cylinder. Is it clean and tight? Also there was a thread on another forum page where a guy had this problem and it turned out to be a faulty fluid level sensor. If you look under the dash there should be a black wire with an orange stripe, this is the RABS diagnostic wire. With the ignition "on" and the ABS light on if you ground this wire the ABS light should blink out any error codes. Another simple check is to make sure both rear brake lights work. Good luck with it as it can be a real PITA to cure.
Old Nov 14, 2008 | 12:53 PM
xtrford's Avatar
xtrford
The rear sensor is a common problem as stated before.....easy fix, mine went out a couple years back.
Old Nov 15, 2008 | 12:01 AM
Thudpucker's Avatar
Thudpucker
My ABS light is staying on after startup, since the Ford Dealer installed that 'Flames' mod.
Is that related or just co-oincedental?
Old Nov 15, 2008 | 05:25 AM
Bobby82490's Avatar
Bobby82490
What is the "Flames" mod?
Old Nov 15, 2008 | 08:34 AM
xtrford's Avatar
xtrford
I'm sure he's talking about the cruise control switch recall....I can't see that affecting your ABS unless the monkeys at Ford were mucking around where they weren't supposed to.
Old Nov 15, 2008 | 10:12 AM
Thudpucker's Avatar
Thudpucker
Right, thanks Brad. For the life of me, when I wrote that post, I couldnt think of why we had to have that switch replaced other than a fire.
In fact, when I brought the truck home after the mod was installed, I left it parked out in the field.....just in case!
Glad to know the Switch is OK and not part of my ongoing CC problem.
mikulskn
Jun 26, 2013 11:23 PM
kbjafd63
Oct 5, 2012 01:42 PM
blee1ash
Mar 8, 2011 11:55 AM
bronco5.8
1978 - 1996 Big Bronco
Jun 28, 2005 09:57 AM
bronco5.8
Aug 13, 2004 10:27 AM
