e4od overdrive will not work
Old Aug 21, 2004 | 01:32 AM
vaughn_roberts's Avatar
vaughn_roberts
could someone please help? trans. shifts fine all except going into overdrive the overdrive lockout light is on but cant make it go to overdrive . I presure washed motor thats when trouble started .Would app. any suggestions.
Old Aug 21, 2004 | 01:40 AM
TigerDan's Avatar
TigerDan
Welcome to FTE! You probably got water into an electrical connection. Did you wash down by the trans as well? Unplug and clean/dry the connections to the trans O/D solinoid.
Also, if you scroll down the main list of forums, you will find a forum specifically for trans, differential, axle and transfer case. Better to ask your question there, or in the forum for your specific truck.
If it's not a truck, you could post it in the General Automotive forum. Hope this helps. -TD
Old Oct 13, 2004 | 08:21 PM
merckx72's Avatar
merckx72
a reply
my ball joints are bad
lievense81
Aug 26, 2015 06:38 PM
20007.3f250
Aug 22, 2015 06:23 PM
FoRdOrDeAtH
Nov 7, 2006 02:50 PM
Doughboy55
Aug 16, 2004 04:21 PM
ChadR93
Nov 29, 2001 11:41 AM
