OVERDRIVE QUESTION/PROBLEM
Old Aug 22, 2015 | 12:19 PM
20007.3f250's Avatar
20007.3f250
What's up guys! OK so my 7.3 is running good.... but today it started to not go into overdrive . It shifts 1 through 3 just fine , automatically and manually. But it will not go into overdrive so the rpms stay around 2100 at 50 mph ... is there a relay or fuse that tells the overdrive to kick in and shift???
Old Aug 22, 2015 | 12:40 PM
20007.3f250
Also I was watching some videos on overdrive switch and I do not believe its the wiring on the column because the overdrive light still turns on and off with the press of the button...... if that helps to know
Old Aug 22, 2015 | 06:23 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There is no fuel or relay involved. You need to get the codes read. The places that read codes free cannot read these codes.
Desperate Dan
Dec 5, 2020 07:39 AM
DadzzTazzDullie
Mar 4, 2008 06:25 AM
OldSchoolRodz
Sep 1, 2005 05:32 AM
chews32
Oct 10, 2004 06:04 PM
cheinz46
Jun 19, 2004 07:22 PM
