Pulled PCM/ FOUND Aftermarket Chip
Old Aug 17, 2004 | 05:45 PM
69crewcab's Avatar
69crewcab
Group
with my problems i had in a previous post of not pulling a code and no MIL
light on with a OBD II scanner, i pulled my pcm to get the part # off of it
and low and behold i find a Hypertech Chip Plugged into the
Service port.
Now, here i thought my truck was stock and ran so good, no i see i am chipped!
Can this chip be my problem of the hiccup while driving??
ANd is this why i was getting codes 603 and 605 for bad ram/ rom?
Old Aug 17, 2004 | 06:32 PM
gunfrk's Avatar
gunfrk
If it ran good with the chip in and you found no corrosion on the chip or pcm I wouldn't think it was the chip. What have you found in codes since the chip removal?
Old Aug 17, 2004 | 06:37 PM
69crewcab's Avatar
69crewcab
Nothing for codes i found !
I also tried to turn on the MIL light thru the OBD II scanner and it still
wont light with the scanner tool.
So i'm thinking bad PCM?? Or am i nuts since theres no codes?
And man what a difference without the chip, its like driving a Ch*vy now
slow and not as powerful.
Old Aug 17, 2004 | 06:45 PM
gunfrk's Avatar
gunfrk
Yea, I have a Bully Dog 4 bank and never go back to stock. It's like being tied to a stump.
Old Aug 17, 2004 | 06:49 PM
69crewcab's Avatar
69crewcab
Now i'm really stumped, on whats causing the hiccup.
I guess i'll swap in another pcm and put back the chip and
see what happens.
Old Aug 17, 2004 | 07:11 PM
Quadzilla's Avatar
Quadzilla
The way the chip attaches to the circuit board inside the pcm is merely a tension mount. After bouncing around, the chip can merely work it's way loose, to where it's not making good contact. Reinstall it, and be sure it's seated properly on the circuit board. To be sure it doesn't move around, secure it with duct tape.
Old Aug 17, 2004 | 07:18 PM
69crewcab's Avatar
69crewcab
thanks
i also noticed i do not have a mount in the back of the computer, so the computer
can move around it looks like..What am i missing in the back behind the
emergency brake
joe
Old Aug 17, 2004 | 08:43 PM
f350xlt460's Avatar
f350xlt460
The same problem happened to me when i first bought my truck used. Although, i tried to program it with a chip in and then had big problems. Took the pcm out to get # and found chip. All is good now.
Ive been running the programer for almost a year now and am curious about temps with chip ( i now have gauges). Could someone refresh my memory on the install process of a chip? Thanks.
Themoose56
Feb 23, 2015 07:31 PM
farmdad
Nov 20, 2014 09:41 AM
cjgray1974
18
May 20, 2014 03:17 PM
LaCount Enterprises
Mar 19, 2014 06:31 PM
Powerstroke-7.3
Feb 24, 2013 03:04 PM
