I installed a three pillar mount w/ pyro, boost and oil press. The install went well, boost and pyro are working fine but the oil pressure gauge is not. I put the sending unit in two weeks prior to the install cause that's when I changed my oil. I installed it in the 1/8 in. plug near the oil filter. When the ignition is turned on the gauge acutually moves counter-clockwise. Is this a bad sending unit? Is there any way to trouble shoot this?
They way you say the gauge moves backwards when you turn the ignition on - I'm assuming before you start the truck - I'd double check the wiring at the gauge first. Sounds like somethings a little backwards.
