1995 4wd automatic hub removal
Old Aug 16, 2004 | 04:33 PM
kchawk's Avatar
kchawk
I pulled the outer cover off (3-screws)and there was a cap right behind it,how does that cap come off?
Old Aug 16, 2004 | 07:16 PM
ovalholic's Avatar
ovalholic
There is a snap ring that is inside of the tube that must be removed. You should be able to get it out of the groove with a strong pick or a small screw driver. That "cap" that you see is the outer side of the locking hub. In case you don't know, if you are going after the wheel bearings you are going to need a special socket to get the nut off.
Old Aug 17, 2004 | 07:57 AM
kchawk's Avatar
kchawk
thanks for the reply it had me scatchin my head but now that makes sense i do have the socket.but thanks again
69issofine
Dec 10, 2014 12:59 PM
yfz 450
Dec 4, 2014 12:05 PM
brsexton
Aug 13, 2009 09:08 AM
Robert6401
Jul 11, 2009 03:49 PM
phorbin2
Aftermarket Products
Jul 16, 2004 11:12 PM
